Wired Intelligent Edge
AOS Switch - Create local user with Level-15 access
This thread has been viewed 43 times
  • 1.  AOS Switch - Create local user with Level-15 access
    Posted Jul 05, 2019 11:39 AM
    I am wondering how to create a local user with Level-15/manager access?  I'm looking for the Cisco equivilent of "username cisco privilege 15 secret cisco"
    I have tried:
    aaa authentication local-user admin group Level-15
    aaa authentication local-user admin group manager
    aaa authentication local-user admin group Administrators
    Nothing works as the groups do not exist, even though the documentation hints at these being the default names.
    Any help is appreciated.
  • 2.  RE: AOS Switch - Create local user with Level-15 access
    MVP GURU
    Posted Jul 05, 2019 03:30 PM
    I suspect the best equivalence of Cisco IOS usernam <name> privilege 15 password <password> command would be simply the ArubaOS-Switch password operator user-name <name> plaintext <password> command.
  • 3.  RE: AOS Switch - Create local user with Level-15 access
    Posted Jul 08, 2019 02:43 PM
    Greetings!
    The first example you used should be correct — the default group for manager-level permissions is "Level-15".
    What switch model are you using, and what software version is it running? Did you get a specific error message when you tried the command?
  • 4.  RE: AOS Switch - Create local user with Level-15 access
    Posted Feb 08, 2021 12:26 PM
    Apologies for posting to an old topic but I am having the same issue.
    On a
    HP J8698A Switch 5412zl
    Software revision K.16.02.0026
    I ran "aaa authentication local-user <username> group Level-15 password plaintext" from the (config) prompt and got back "Authorization group Level-15 does not exist."
    but on
    HP J9851A Switch 5412Rzl2
    Software revision KB.16.10.0007
    The command runs properly and creates my user and prompts for the password.
    Shane McCook
  • 5.  RE: AOS Switch - Create local user with Level-15 access
    Posted Feb 09, 2021 07:04 AM
    As far as I can see that feature was introduced on 16.02 only on the active platforms at that time (5400R/v2+v3, 2930F, 2920, 2620, 2530). So it is expected that the command is not available on your 5412 non R 'K' platform.
  • 6.  RE: AOS Switch - Create local user with Level-15 access
    Posted Feb 20, 2021 05:20 AM
    Hi Herman Robers
    I am not able to create local user on the Aruba Switch Model 2530, the rest models which you have mentioned above the same commands are working fine to create a local user.
    We are using version YA.16.10.0012  and the error is "Authorization group Level-15 does not exist"  can you please help how it works for model 2350.
    sandeep singh
  • 7.  RE: AOS Switch - Create local user with Level-15 access
    Posted Feb 22, 2021 06:04 AM
    It should work the same as on the other switches that do work. If it doesn't, either my information is incorrect, or this is a software defect.
    EDIT: I did not look right. The document I used, the Switch Software Feature Matrix, appears to be public, so you can have a look yourself.
    Check for the feature RBAC: Role Based Access Control, and see there confirmed that this feature is unavailable on the 2530. Sorry for the confusion, I think I checked local user role before, which is supported.
