AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
  • 1.  AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
    Posted Jan 08, 2018 02:11 AM
    Hi everyone,
    I faced many issues in AOS VMC 8.2.0.2 B62929 in my Lab. I tried to install for twice.
    I have 3 VLANs (1, 150, 160).
    Controller IP and Mangament are in VLAN 150.
    Port is Trunk and Native VLAN is 1.
    AOS, AP, PEF licenses are installed. AP-325 joined the controller .
    1. Module Layer 2/3 is busy. While only one client obtaining IP address from the controller act as DHCP server. For a minute, the controller reboot itself. Sometimes, it happens after use cmd #show ip interface brief.
    2. I do not know that does it mean. Please see the screen capture below.
    3. The controller cannot be shutdown. Please see the screen capture below.
    Please help me to solve. Thanks.
  • 2.  RE: AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
    Posted Jan 09, 2018 06:53 PM
    I would open a TAC case if this is being deployed on a supported platform. What is this deployed on, what are the ESX or KVM server specs, etc?
  • 3.  RE: AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
    Posted Jan 09, 2018 10:50 PM
    Hi Howard,
    I deployed on ESXi 6.0 on Nutanix.
    Specs. on host
    -CPU 20 x 2.799 GHz
    -Memory 262 GB
    -Storage a lot.
    For VMC, 4 vCPU, 8GB of Memory.
  • 4.  RE: AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
    Posted Jan 10, 2018 11:59 AM
    So you could certainly try to open a TAC case, but I don't think that would be supported or it's not something that we would have QA'd or tested. Nutanix kind of does things with it's network fabric differently than a pure ESX host, so it's hard to know if that is related to this or if it's something else. For example, if the ESX host/hardware has multiple network interconnects, those MUST be using DvSwitch and LAG (not just nic teaming) to handle virtualized network switches (which is what the controllers are), and I don't know how much of that is exposed in the Nutanix interface to be configurable.
  • 5.  RE: AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
    Posted Jan 10, 2018 12:00 PM
    What Nutanix product are you running this under?
  • 6.  RE: AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
    Posted Jan 11, 2018 05:58 AM
    Hi Howard,
    Nutanix is hypercoverged server.
    I setup this for Lab and demonstration. So I am not sure I can open case or not.
    Please advise.
  • 7.  RE: AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
    Posted Jan 11, 2018 09:56 AM
    Just to clarify - are you running this on Nutanix/VMware, or on a pure Nutanix AHV system?  I'm running the Nutanix/VMware option and it's working fine in my lab.  The AHV configuration is basically a KVM variant, though, which would put you in a totally different scenario.
  • 8.  RE: AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
    Posted Jan 11, 2018 09:47 PM
    It is running on VMware on Nutanix server.
    Is it according to Virtual Disk Format? It is now using Thin provision.
