AOS10 'Cluster' comfigurations
This thread has been viewed 43 times
  • 1.  AOS10 'Cluster' comfigurations
    Posted May 04, 2022 07:33 AM
    I am a Partner demonstrating new AOS10 capabilities with a small deployment. A large customer had a great question!
    They use Aruba Central today with a separate cluster in each of many buildings (dozens of buildings). Each cluster may have all SSID's but have custom RF tuning per-build (as an example). This is the beauty of Group Level and VC/Cluster level config is that we can have one set of configs but then have one-off configurations per-cluster.
    How is this accomplished with AOS10 which is cluster-less, no VC?
    My answer was a separate group for each building. Then they asked how they would make an SSID change or add a new User-Role. Would they have to go to each group? Naturally the answer was, yes. Then I got blank stares and concerned how they would manage the environment moving forward... without the need for API's and functions outside of Central to accomplish the same group/vc configs as in AOS6/8.
    Thoughts?
    Philip Wightman, ACEX (AMFX) #69. Aruba Partner Ambassador
  • 2.  RE: AOS10 'Cluster' comfigurations
    Posted May 06, 2022 07:00 PM
    you can have different groups for sure, you can also have device level configuration which will be used over the group configuration.
  • 3.  RE: AOS10 'Cluster' comfigurations
    Posted May 10, 2022 07:27 AM
    Device level configurations are great for one-off configurations but not the same as Cluster configurations. Some buildings for larger customers may have several hundred AP's in each of several buildings.
    Maintaining a separate group for each building will be the way to go. Creating or manipulating an SSID then would be a matter of how many groups you have. This is not the worse ever, we just lose one level of configuration granularity we have today.
    Philip Wightman, ACEX #69
  • 4.  RE: AOS10 'Cluster' comfigurations
    MVP EXPERT
    Posted May 11, 2022 06:33 PM
    You can clone a group and create a separate group for low density and a high density with different RF profiles.
    Local override at device level is possible for some smaller tweaks per AP.
    It should be awesome if we could export/import  configuration parts form one the another group of device level.
    Marcel Koedijk | MVP Expert 2022 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
