Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
AOS10.x for AP 600 serie release
This thread has been viewed 36 times
  • 1.  AOS10.x for AP 600 serie release
    Posted Jan 25, 2023 03:49 AM
    Hi all,
    at today end of  January 2023 it seem AP 600 series are still not supported for AOS 10.x
    so they can not be used in Central in version 10.x
    See AOS 10 supported-devices
    Do you have any news about the release of the firmware?
  • 2.  RE: AOS10.x for AP 600 serie release
    Posted Jan 25, 2023 04:51 AM
    635 and 655 APs are going to be supported with the next Central update, which is going to be rolled out on the different clusters in February. This update will include 10.4 which will be minimum for these APs, as far as I know.
    https://www.arubanetworks.com/techdocs/central/2.5.6/content/aos10x/aos10x-overview/supported-devices.htm
    https://www.arubanetworks.com/techdocs/central/2.5.6/content/whats_new/central256.htm
    I could not find info about the 615 APs
    Bjarne
  • 3.  RE: AOS10.x for AP 600 serie release
    Posted Jan 25, 2023 05:12 PM
    i think it will be the same for AP-615.
  • 4.  RE: AOS10.x for AP 600 serie release
    Posted Feb 01, 2023 07:25 AM
    It was confirmed in a 2.5.6 "Whats New" broadcast that 615 will not be supported directly after the 2.5.6 update with AOS 10.4
    This matches the supported devices list
    https://www.arubanetworks.com/techdocs/central/latest/content/aos10x/aos10x-overview/supported-devices.htm
    Bjarne
  • 5.  RE: AOS10.x for AP 600 serie release
    Posted Feb 03, 2023 11:16 PM
    yes, note that you can run AP-615 with Aruba InstantOS 8.11.x.x
  • 6.  RE: AOS10.x for AP 600 serie release
    Posted Feb 10, 2023 11:03 AM
    Any timeline when there will be support for the AP-615.
    Just installed it with a customer and wanted to use AOS10.
    Will there ever be support for these AP serie (AP-615)?
  • 7.  RE: AOS10.x for AP 600 serie release
    Posted Feb 10, 2023 05:55 PM
    yes AP-615s will be supported on AOS10
  • 8.  RE: AOS10.x for AP 600 serie release
    Posted Feb 14, 2023 12:13 PM
    Reach out to your local Aruba Sales team for roadmap information if you need a timeline. Unfortunately that cannot be discussed in a public forum.
