Hi NesaM,
1. Be sure your controller ipsec psk is add to the MM configuration
HomeLAB-MM01) [mm] (config) #localip #.#.#.# ipsec yoursecret
Note: This is the IP of your MD controller.
2. Make a managed device folder hierarchy.
(HomeLAB-MM01) [md] (config) #configuration node /md/HomeLAB
3. Add your MD device to the managed device group
(HomeLAB-MM01) [mm] (config) #configuration device ##:##:##:##:##:## device-model MC-VA /md/HomeLAB
Note: This is the mac-adres of your MD Controller, run "show switchinfo" on your MD to get this.
Note: The hostname in the GUI under managed devices will be inherited from the MD devices.
(HomeLAB-MM01) [mm] (config) #cd HomeLAB-mc01
(HomeLAB-MM01) [mm] (config) #hostname giveitaname
4. Wait some minutes for the controllers are synced
(HomeLAB-MM01) [mm] (config) #show switches
Hope this helps you!
