aos8 and l3 gre not working
  • 1.  aos8 and l3 gre not working
    Posted Nov 24, 2022 09:44 AM
    i have the following setup on 8.6, but the l3 gre tunnel is not working.
    (vpnc1) #show configuration diff /md/myVPNC/20:4c:03:03:bf:80 /md
    - ip route 192.168.63.0 255.255.255.0 1.1.2.2
    - country US
    - masterip 10.1.69.201 ipsec aruba123 interface vlan 60
    - clock timezone America/Detroit
    - hostname vpnc1
    - interface vlan 60
    -     ip address 10.1.60.100 255.255.255.0
    -     ip nat outside
    - interface vlan 63
    -     ip address 192.168.6.1 255.255.255.0
    -     operstate up
    - interface vlan 99
    -     ip address 1.1.1.1 255.255.255.252
    - ip name-server 10.254.1.21
    - interface tunnel 1
    -     ip address 1.1.2.1 255.255.255.255
    -     tunnel source vlan 99
    -     trusted
    -     tunnel destination 1.1.1.2
    -     tunnel mode gre ip
    -     tunnel keepalive 5 2
    - controller-ip vlan 60
    - interface gigabitethernet 0/0/0
    -     description GE0/0/0
    -     switchport access vlan 60
    -     switchport mode trunk
    -     switchport trunk allowed vlan 60-61,99
    -     switchport trunk native vlan 60
    -     trusted
    -     trusted vlan 1-4094
    - ip default-gateway 10.1.60.1 1
    - vlan 60
    - vlan 99
    - vlan 63
    - vlan 61
    (MC2) #show configuration diff /mm/mynode /mm
    - ip route 10.0.0.0 255.0.0.0 1.1.2.1
    - country US
    - hostname MC2
    - interface vlan 60
    - interface vlan 73
    -     ip address 192.168.63.1 255.255.255.0
    -     operstate up
    - interface vlan 99
    -     ip address 1.1.1.2 255.255.255.252
    -     ip address 1.1.2.2 255.255.255.255
    -     trusted
    -     tunnel destination 1.1.1.1
    -     tunnel keepalive
    - controller-ip vlan 73
    -     switchport trunk allowed vlan 60,73,99
    -     trusted
    - vlan 60
    - vlan 99
    - vlan 73
    (vpnc1) *#show ip interface br
    Interface IP Address / IP Netmask Admin Protocol VRRP-IP
    vlan 60 10.1.60.100 / 255.255.255.0 up up
    vlan 1 unassigned / unassigned up down
    vlan 63 192.168.6.1 / 255.255.255.0 up up
    vlan 99 1.1.1.1 / 255.255.255.252 up up
    loopback unassigned / unassigned up up
    tunnel 1 1.1.2.1 / 255.255.255.255 up up
    (vpnc1) *#show datapath tunnel table
    Datapath Tunnel Table Entries
    # Source Destination Prt Type MTU VLAN Acls BSSID Decaps Encaps Heartbeats Flags EncapKBytes DecapKBytes
    14 SPIE2501400 in 10.1.60.100 50 IPSE 1500 0 routeDest 003C 0 1141 0 T 0 0
    13 SPI79B6D000out 10.1.69.201 50 IPSE 1500 0 routeDest 003C 0 0 2773 T 0 0
    10 1.1.1.1 1.1.1.2 47 800 1100 0 0 0 0 0 0 00:00:00:00:00:00 424 0 424 TFPf
    i cannot ping 1.1.2.1
    i cannot ping through the tunnel.
    I am not sure why the l3 gre tunnel is not working, some advise would be greatly appreciated.  Thanks
  • 2.  RE: aos8 and l3 gre not working
    Posted Nov 24, 2022 10:27 PM
    i got it working...
    so a few points.
    a: you cannot ping the tunnel interface when it is up up, that appears to be normal.  other platforms seem to allow this, so that was confusing to me.
    b: the mm would not allow me to push keep-alive parameters to the vpnc1 host, but the standalone would, they did not seem to show up as expected in encap decap counters, so that also set me back a bit, i ignore that now
    c. just setup a static route on each side of the tunnel with the next hop being the unpingable local tunnel ip... and it does work.
