AOS8 bulk provision APs for wired 802.1X
  • 1.  AOS8 bulk provision APs for wired 802.1X
    Posted Oct 22, 2019 09:46 PM
    AOS 8.3.0.x with MM (some controllers on 8.2.2.x)
    We have started a wired 802.1X initiative and I found that I cannot provision more than a single AP at a time if I want to set 802.1X settings. We wish to use EAP-TLS with factory cert. I also looked at the CLI audit-trail after provisioning an AP and found the following commands were pushed:
    clear provisioning-ap-list
    read-bootinfo ap-name AP-PLEA-6150-FLR2-18
    copy-provisioning-params ap-name AP-PLEA-6150-FLR2-18
    provision-ap
    provision-ap apdot1x-tls
    provision-ap apdot1x-factory-cert
    reprovision ap-name AP-PLEA-6150-FLR2-18
    However, the "provision-ap apdot1x-tls" command does not exist from the CLI.
    Is there a known method to do this bulk re-provisioning so the APs will start sending their cert?
    We have ~1600 APs.
  • 2.  RE: AOS8 bulk provision APs for wired 802.1X
    Posted Oct 22, 2019 10:07 PM
    You would use a provisioning profile for that:
    https://www.arubanetworks.com/techdocs/ArubaOS_85_Web_Help/Content/arubaos-solutions/1cli-commands/ap-ntw-pro.htm?Highlight=provisioning%20profile
    I would set it up using the GUI for simplicity and apply it to a test ap-group to make sure it works the way you need it to:
