AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
This thread has been viewed 31 times
  • 1.  AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
    Posted Mar 14, 2018 06:38 AM
    I have a testing / lab environment with Virtual Mobility Master and Standby VMM (in L2 redundancy / HA mode) and two VMC's setup and running AOS 8.2.0.2, under VMware ESXi.
    Due to a restructuring of the network infrastructure, I need to move my Virtual MM and Standby MM and both VMC's to a different subnet, and as a consequence all the IP adresses will have to change.
    How can I proceed best with changing the MM ip addresses ?
  • 2.  RE: AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
    Posted Sep 13, 2019 07:46 AM
    Would also like to know this information
  • 3.  RE: AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
    Posted Sep 13, 2019 08:09 AM
    The answer is "it depends".  It depends on what services you require.  Airmatch, Airgroup and anything else that depends on the MM at the time will not run between the time you re-ip the MM and put it where it belongs.
  • 4.  RE: AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
    Posted Sep 13, 2019 09:38 AM
    It would be a pretty instant change.
    How do you go about changing the IPs on the Mobility Master & the Mobility Device – do you need to re-add the controller in the MM with the new IP or can you just amend the IP? Does it lose the config or will it re-sync all config?
    Scott McMullan | Senior Systems Engineer | Kainos | DD: +44 (0)28 9057 1517 | s.mcmullan@kainos.com
  • 5.  RE: AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
    Posted Sep 13, 2019 10:22 AM
    Each Node points to the MM using this command:
    masterip 192.168.1.x ipsec ****** interface vlan 1
    For each node-specific configuration, on the MM, I would change that ip address to the new ip address, first.  When you do a write mem, that  would cut each node off from the MM because it would be pointing to a new ip address.  You would then re-ip the MM.  After the MM is changed to the new ip address, the nodes should re-connect, because they MMs are identified by their mac address.
    **That is the general description of how it could be done.  The details of how that is accomplished could be more complicated based on your setup**
  • 6.  RE: AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
    Posted Sep 24, 2019 02:02 AM
    What about this ipsec key? Should we enter this on only MM or both MM and controllers? Should we use the ipsec key in installation before or does it matter if we can use any key?
    Thanks.
  • 7.  RE: AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
    Posted Feb 22, 2022 10:33 AM
    I guess the controllers will restart instantly as soon as the changes are committed?
    Will they start operating again after the restart even if the new master ip is not reachable at that time?
    So will wifi be usable while virtual mobility conductor is not reachable?
    Normally, if master is not reachable for some hours I know that this is not a problem for a controller-based architecture. But not sure what effects this change has ...
  • 8.  RE: AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
    Posted Dec 02, 2022 12:38 PM
    Finally, somebody did this operation successfully?
    I'm in the same situation and I need to be sur that the configuration and access to the mobility controller will not be wipe when I change the Ip and subnet of the mobility controller.
    regards,
  • 9.  RE: AOS8 Change Virtual Mobility Master MM and StandbyMM subnet & IP addresses
    Posted Dec 05, 2022 04:38 AM
    May be best to work with your Aruba partner, Aruba Support, and/or test this in a lab. Most customers don't change IP subnets on a regular basis, so it's important to do this well prepared and have someone available in case you get stuck.
    I could imagine that moving the Standby VMM first, and using the VMM redundancy may be an option to explore. If you lose connection between MD and MM you can after you fixed the config in the MM to what it should be, change the config in disaster-recovery mode on the MD to restore the connectivity. As mentioned above, you lose some features like AirMatch, AirGroup during when the MD can't communicate with the MM.
