AOS8 Clone or Rename AP GROUP
This thread has been viewed 38 times
  • 1.  AOS8 Clone or Rename AP GROUP
    Posted Apr 18, 2019 10:49 AM
    Mobility Master design
    Can you clone an AP group?
    Can you rename an AP group?
    Thanks!
  • 2.  RE: AOS8 Clone or Rename AP GROUP
    Posted Apr 18, 2019 10:54 AM
    You cannot rename an ap group.  You can clone it, however.
    config t
    ap-group <new name>
    clone <old name>
  • 3.  RE: AOS8 Clone or Rename AP GROUP
    Posted Apr 18, 2019 11:03 AM
    Thanks for the quick responses guys!
    AP-Renaming - X
    Cloning....
    How do you clone an AP Group via CLI on the MM at the hierarchial scale of lets say
    /md
    /md/Super-Corp (AP Group resides here)
    If I go to the MCs themselves I can see the ap-groups
    logon switch x
    show ap-group
  • 4.  RE: AOS8 Clone or Rename AP GROUP
    Posted Apr 18, 2019 11:14 AM
    cd /md/Super-Corp
    config t
    ap-group <new group>
    clone <existing group>
    write mem - pushes config to mds
  • 5.  RE: AOS8 Clone or Rename AP GROUP
    MVP
    Posted Apr 18, 2019 11:17 AM
    Or if you are askign to clone it from  /md/Super-Corp to /md; that is not possible.
  • 6.  RE: AOS8 Clone or Rename AP GROUP
    Posted Apr 18, 2019 11:50 AM
    Thanks that did the trick!
    I was thrown off by the fact I cant see the running config of the specific group even if you change the directory to the group
    cd /md/Super-Corp
    show ap-group - not allowed command.
    show run - shows same running config as MM
    show run | inc ap-group
    default ap groups shown.
  • 7.  RE: AOS8 Clone or Rename AP GROUP
    Posted Apr 18, 2019 02:38 PM
    Hi
    You should use the command:
    show configuration effective
    that will show the configuration from that level
  • 8.  RE: AOS8 Clone or Rename AP GROUP
    MVP
    "Submit As" which I think should be a clone, does nto seem to be working for me.
    Through CLI however the clone options still works flawless (ie. ap-group <new-group> clone <old-group>) so that is what I've been using.
    Renaming pretty much anything is not possible with Aruba controllers. AP-group cannot be renamed.
    Remember that if you're using cloning to try and rename an ap-group, this will not change for your AP's so you will have to move them into the new group which requires the AP to reboot.
