AOS8 - config failure after changing regulatory domain settings
  • 1.  AOS8 - config failure after changing regulatory domain settings
    Posted Mar 22, 2019 06:38 AM
    Dear all!
    On a newly installed system, I would like to set which channels the APs can use. At the appropriate level (MD group) on the Mobility Master, AP Group -> <groupname> -> Profiles -> AP -> Regulatory Domain displays the ap-group specific RD profile (<apgroupname> _rdp_ui), and I have blocked some 5GHz channels (like channel 165).
    After I deployed the configuration, I received the following errors:
    (MobilityMaster) [mynode] #show configuration failure all
    All Configuration Failure
    IP Address    MAC                Config ID  Process          Command                    Message
    10.75.75.137  20:4c:03:2b:4d:3c  51         Profile Manager  no valid-11a-channel 165   Item not in list
    10.75.75.138  20:4c:03:2b:4e:5c  51         Profile Manager  no valid-11a-channel 165   Item not in list
    Total switches with config failures::2
    I got same errors if I disabled channel 149, 153, 157 and 161 example.
    How do I make the desired changes without getting errors?
    Thanks!
  • 2.  RE: AOS8 - config failure after changing regulatory domain settings
    Posted Mar 25, 2019 04:45 AM
    Does anyone have an idea about this?
    Thanks!
  • 3.  RE: AOS8 - config failure after changing regulatory domain settings
    MVP EXPERT
    Posted Mar 25, 2019 06:32 AM
    Whats the AP model (eg 305US or ROW) and the regulatory domain currently set to? Are you also using bonded channels within your environment?
  • 4.  RE: AOS8 - config failure after changing regulatory domain settings
    Posted Mar 25, 2019 07:31 AM
    AP315 and AP345 RW models are used, and Regulatory Domain is set to HU.
    Current channel settings:
    2,4GHz: 20Mhz allowed only
    5GHz: 20MHz and 40MHz allowed only
    Current firmwares:
    MM: 8.3.0.1
    MDs: 8.3.0.1
    I would like to disable UNII-III and ISM channels: 149-165
  • 5.  RE: AOS8 - config failure after changing regulatory domain settings
    Posted Mar 25, 2019 08:32 AM
    Correct myself:
    The config failure occurs when channel 165 is part of the deploy. If I skip it (remains enabled) and I disable 149-161 under regulatory domain settings, deployment runs properly, and everything is OK.
    So it's seem to be the problem is only with the channel 165, if it is the part of the disabled channels.
    If 149-161 was disabled earlier, and I disable 165 after that (in a separate deploy), it runs correctly.
    Is this possible a bug in AOS?
  • 6.  RE: AOS8 - config failure after changing regulatory domain settings
    Posted Mar 25, 2019 09:41 AM
    Sounds like an order of operations bug in AOS 8.3. You can open a TAC case to file it. For what it's worth, in 8.4.0.1 I don't see it (I can disabled 149-165 in one modification)
