AOS8 deployment with VMM and 7210 controller
  • 1.  AOS8 deployment with VMM and 7210 controller
    Posted Dec 18, 2019 12:00 AM
    I'm in the phase of doing test with 2xVMM and 3x7210 controllers in a single cluster with AOS8.3.0.10. All the controllers are in L2 mode.
    Regarding the clustering of 7210 controllers, bit confused. How the vrrp should be configured in each of the controllers. Is VRRP IP and LMS-IP be the same IP address. Is it mandatory to have LMS-IP for a single cluster?
    In this scenario CoA will be used pointing to external Radius server. Is CoA ip address be the VRRP/lms-ip ..?
    Can someone help with configs mentioned below for each of the 7210 controllers
    Configs
    Controller1: 10.1.1.1
    Controller2: 10.1.1.2
    Controller3: 10.1.1.3
    VRRP: 10.1.1.254
    lc-cluster group-membership "7210-Cluster"
    vrrp xx
    priority xxx
    ip address xx
    vlan xx
    no shutdown
    controller 10.1.1.1 priority 128 mcast-vlan 0 vrrp-ip <xx.xx.xx.xx> vrrp-vlan <x> group <x>
    lms-ip <x.x.x.x>
    Is there any valid config guide.
  • 2.  RE: AOS8 deployment with VMM and 7210 controller
    Posted Dec 18, 2019 04:06 AM
    I personally do not use the LMS-IP when clustering so it isn't mandatory.
    Regarding RADIUS COA, for each member to use RADIUS CoA then you will want to create a VIP on each cluster member and add these into your radius as well as the IP's of the controllers (that is what i do anyway)
    A good way to do the config really easily is going to the below URL and log in.
    https://ase.arubanetworks.com/solutions/id/143
    When here go through each tab and enter all the required information, once done it'll output the code and config required to configure this for you.
    Any questions please feel free to let me know.
  • 3.  RE: AOS8 deployment with VMM and 7210 controller
    Posted Dec 18, 2019 04:13 AM
    An EXAMPLE configuration based on what you have provided, i also added additional IP's and VLANs and so on but it outlines the principle.
    no paging
    configure terminal
    #Group-level configuration
    cd /md
    lc-cluster group-profile 7210-cluster
    write memory
    #Device-level configuration
    #Cluster Member #1
    cd /md/test/controller1
    lc-cluster group-membership 7210-cluster
    lc-cluster exclude-vlan 20
    write memory
    vrrp 100
    ip address 10.1.1.254
    priority 255
    advertise 1
    vlan 10
    no shutdown
    write memory
    #Cluster Member #2
    cd /md/test/controller2
    write memory
    vrrp 100
    priority 250
    advertise 1
    vlan 10
    no shutdown
    write memory
    #Cluster Member #3
    cd /md/test/controller3
    write memory
    vrrp 100
    priority 245
    advertise 1
    vlan 10
    no shutdown
    write memory
    cd /md
    controller 10.1.1.1 vrrp-ip 10.1.1.100 vrrp-vlan 10
    controller 10.1.1.2 vrrp-ip 10.1.1.101 vrrp-vlan 10
    controller 10.1.1.3 vrrp-ip 10.1.1.102 vrrp-vlan 10
    redundancy
    active-ap-lb
    write memory
    This is the sort of output you can expect which is all the needed config, however, as I mentioned above it'll be slightly different due to you knowing your environment.
  • 4.  RE: AOS8 deployment with VMM and 7210 controller
    Posted Dec 18, 2019 06:31 AM
    @ailart wrote:
    Configs
    VRRP: 10.1.1.254
    vrrp xx
    priority xxx
    ip address xx
    vlan xx
    no shutdown
    lms-ip <x.x.x.x>
    VRRPs and what you need them for when clustering are probably the most difficult things to explain in ArubaOS 8.x.
    VRRP type 1 - For access points to discover a controller when they (the access points) come up for the first time.
    A controller cluster would have two or more controllers that each have a management ip address.  In the simplest deployment you would have a two controller cluster like this:
    Controller1 - 192.168.1.7/24
    Controller2 - 192.168.1.8/24
    VRRP - 192.168.1.100/24
    New Access Point1 - 192.168.2.1/24
    Since the access point above does not share the same layer 2 subnet as the two controllers in a cluster, we would have to figure out a way for the access point to discover the controller cluster in a different subnet, when the access point is new (Note: after an access point discovers a cluster, it saves the management ip addresses of all of the controllers in the cluster into  AP flash, and those ip addresses are used for discovery on subsequent reboots). Many people point the "aruba-master" dns a-record to a single ip address or use dhcp option 43 to point to a single ip address when an access point is new for it to discovery a cluster.  Configuring the aruba-master  a-record or dhcp option 43 to 192.168.1.100 will allow new access points to discover a cluster using a single ip address, regardless of which controller is currently "up".  Again, after the initial discovery of a cluster, aruba-master and dhcp ooption 43/60 are not used.  You would configure the VRRP for this function individually at the node (controller level) for each controller:
    vrrp 20
    priority 100
    ip address 192.168.1.100
    vlan 20
    no shutdown
    VRRP type 2 - For COA. THIS IS COMPLETELY OPTIONAL.
    This is defined in the Cluster Configuration at the folder above the controllers. This VRRP is separate from the VRRPs used for initial controller discovery and consumes a separate ip address for each controller on your controller management subnet:
    lc-cluster group-profile new-cluster
    controller 192.168.1.7 vrrp-ip 192.168.1.20 vrrp-vlan 20
    controller 192.168.1.8 vrrp-ip 192.168.1.21 vrrp-vlan 20
    (the RFC 3576 configuration would also be needed to be configured in the AAA profile and on the radius server for COA to work, by the way).
    The configuration above will automatically setup two VRRP instances starting with VRRP 220:
    The example above automatically sets up VRRP 220, ip address 192.168.1.20, with controller 192.168.1.7 being the master of VRRP 220 and controller 192.168.1.8 being the backup on VRRP 220.  It also automatically sets up VRRP 221, with ip address 192.168.1.21, with controller 192.168.1.8 being the master and controller 192.168.1.9 being the backup.
    So this is what you have:
    VRRP 220- 192.168.1.20: Controller 1 - 192.168.1.7 master, Controller 2 backup master
    VRRP 221- 192.168.1.21: Controller 2 - 192.168.1.8 master, Controller 1 backup master
    Why is the 220 and above VRRP necessary for COA?  When a client is on a controller cluster and sends a radius request, the radius server would need to know later which controller (md) sent the first  client request so that if the radius server later needs to send a COA, it would know which md to send it to. When a radius request is sent from a cluster MD, whatever VRRP 22x the cluster MD is the master of is sent as the source ip address of the radius request.  For example if a radius request is sourced from the controller with ip address 192.168.1.7, the source ip address of the radius request is sent as 192.168.1.20.  Later, if that client's state needs to be changed via COA, the radius server will send the COA to ip address 192.168.1.20 to execute the COA.  Are you still following?  Good.  The multiple VRRPs above 220 are needed just in case a cluster controller goes away there will still be a controller available to answer COA requests for authentications that occurred before the controller went away.  Using our current configuration as an example:
    A client on controller 1 (192.168.1.7) sends a radius authentication to the radius server.  Controller 1 sends the radius source ip address as 192.168.1.20 (the master of VRRP 220).  If controller 1 goes down, Controller 2 will take over as the master of VRRP 220, and controller 1's clients will fail over to controller 2 and controller 2 will be able to answer COAs that were previously sent by controller 1 with a source ip address of 192.168.1.220.  I hope that even make sense.
    I do not typically advise setting up VRRP ip addresses in your cluster configuration because:  putting a VRRP ip address in your cluster configuration (1) consumes more ip addresses on your management subnet and (2) It also introduces more multicast traffic (VRRP) on your management subnet that could be significant depending on how many controllers are in your cluster and how much other broadcast traffic is hitting the controller on client subnets (3) The majority of users either don't have COA configured properly or they simply do not use it often enough to justify the configuration complexity and maintenence moving forward.
    tl;dr - Don't bother with adding VRRPs to a cluster configuration if you have not previously tested COA successfully or are not using it actively.  You can always add it later if need be.
    For more reading, please look at the thread here:  https://community.arubanetworks.com/t5/Wireless-Access/Clustering-MD-in-8-x-The-need-for-VRRP-IP/td-p/303775
