AOS8 fresh install
  • 1.  AOS8 fresh install
    Posted Sep 27, 2022 09:00 AM
    Hello airheads!
    We have a 7010 controller that we have used in the past for RAPs. There is currently only one left on there and I would like to take the controller to AOS8. I've found various vids and docs on the setup but nothing about a fresh install. How do I go about getting the AOS8 code on there and starting fresh? I don't need to keep any config.
    -Mike
  • 2.  RE: AOS8 fresh install
    Posted Sep 27, 2022 04:42 PM
    If you upload 8.x code to a 6.x controller, you effectively do a write erase all.
    Please see the document here, if that is what you are trying to do:  https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedAssets/Migration_to_ArubaOS_8_Tech_Note.pdf
  • 3.  RE: AOS8 fresh install
    Posted Sep 28, 2022 06:51 PM
    Hi, if you don't need to keep any config you can upload the AOS8 code to the controller, boot on  V8, then make a write erase and you can start fresh.
    In the initial wizard just make sure to select standalone if you don't have the Mobility Conductor VM.
    Hope this helps.
  • 4.  RE: AOS8 fresh install
    Posted Sep 29, 2022 08:08 AM
    Thanks to both of you for the info!
