Hi All,
Does anyone know if AOS8 controller/mm will be available in the Azure Marketplace as an add-on? I have a few customers asking that want to completely remove every infrastructure device other than switches to the cloud/Azure.
-n
HiMay be a bit off topic but have you looked at Aruba Central for these cutomers?More devices and features are added to central all the time.Cheers
Would it (already) be possible to install OS8 in Azure?
Not currently supporting VMC/VMM in any cloud platforms.
