AOS8 Master Controller Mode openflow-profile alert
  • 1.  AOS8 Master Controller Mode openflow-profile alert
    Posted Jun 20, 2017 06:03 AM
    I'm setting up wireless at a customer. I have chosen to use AOS8 on 2 7205 controllers without a MM in Master - Redundant Master mode. When budget allows they might invest in a MM but the budget is set pre AOS8.
    I see the following alert on both controllers: "openflow-profile is not supported in Master Controller Mode"
    I get the same error when I try to delete/disable the openflow-profile. Is there any way to get rid of this alert? ArubaOS 8.1.0.1
    txs, Erik
  • 2.  RE: AOS8 Master Controller Mode openflow-profile alert
    Posted Jun 20, 2017 10:57 AM
    You are seeing this in the alerts on the GUI?
  • 3.  RE: AOS8 Master Controller Mode openflow-profile alert
    Posted Jun 20, 2017 02:05 PM
    Yes, it comes up as an alert in the upper message section of the GUI. I tried removing the profile from the CLI but that gave the same error.
    I stopped configuring AOS8 and went back to 6.5 at this customer because I ran into too much unknowns and not enough time to figure them out. More labtime needed here.
    txs, Erik
  • 4.  RE: AOS8 Master Controller Mode openflow-profile alert
    Posted Nov 24, 2018 05:16 AM
    As per AOS8  "Enable the OpenFlow controller on the MM, and the OpenFlow Profile in managed nodes"
    MM> Configuration > System >profile > Controller profile > OpenFlow-controller
