AOS8 mdconnect
  • 1.  AOS8 mdconnect
    Posted May 14, 2019 05:11 AM
    We are implementing AOS8.4.0.2 and I am configuring the new MDs. If I want to look at the config from the CLI I believe I need to cd to the actual node, and then type 'mdconnect', but when I do that I get an error:
    (master-8a) [00:1a:1e:xx:xx:xx] (config) #mdconnect
    Redirecting to Managed Device Shell
    Permission denied: wrong username or password
    Exiting Managed Device Shell
    Is there something else I need to configure to make this work?
  • 2.  RE: AOS8 mdconnect
    MVP EXPERT
    Posted May 14, 2019 05:44 AM
    Can you SSH directly to the MD's with the same username and password?
  • 3.  RE: AOS8 mdconnect
    Posted May 14, 2019 07:24 AM
    I can SSH to all of the controllers. But when I issue the 'mdconnect' command it doesn't actually ask me for a password, it just instantly comes up with the error message, which makes me wonder if I am supposed to have activated/configured mdconnect somewhere?
  • 4.  RE: AOS8 mdconnect
    Posted May 15, 2019 12:30 AM
    You don't have to configure anything for mdconnect to work, not explicitly anyways.
    Do your MDs show up on the MM? I think the mdconnect command uses locally configured mgmt-users and SSH keys. I have this configured on all of my MDs and MM:
    mgmt-user ssh-pubkey client-cert master-ssh-pub-cert seamless-logon read-only node
    mgmt-user ssh-pubkey client-cert master-ssh-pub-cert seamless-logon-w standard node
    (mmisbaruba1) *[00:1a:1e:02:39:d8] #show mgmt-user ssh-pubkey
    SSH Public Key Management User Table
    CLIENT-CERT           USER               ROLE        STATUS   REVOCATION CHECKPOINT  Max-concurrent-sessions
    master-ssh-pub-cert   seamless-logon     read-only   ACTIVE   none                   N/A
    master-ssh-pub-cert   seamless-logon-w   standard    ACTIVE   none                   N/A
    If that's missing I'm not sure how to configure it.
  • 5.  RE: AOS8 mdconnect
    Posted May 17, 2019 07:52 AM
    Thanks for looking. Hmmm, yes those are already configured
  • 6.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 04:00 PM
    Did you ever get this working? I'm having the same issue.
  • 7.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 04:40 PM
    It is working, but I'm afraid (unhelpfully) I don't remember what got it working. I'm not sure I (knowingly) did anything to fix it. What version of AOS are you running?
  • 8.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 04:42 PM
    8.5.0.2
  • 9.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 04:48 PM
    Is your cluster properly L2 connected?
  • 10.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 04:56 PM
    @tmcclintic wrote:
    8.5.0.2
    Okay.  Just to see if this is your issue, please SSH into the MD and type this:
    show running-config | include master-ssh-pub-cert
  • 11.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 05:03 PM
    I don't have a cluster, I'm using L3 Redundancy for the MM.
    From a MD here is the output:
    Building Configuration...
    crypto-local pki PublicCert master-ssh-pub-cert
    I should note that the MDs are actually running 8.4.0.4 still.
  • 12.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 05:27 PM
    That does not match a bug fixed in 8.3.x.
    What are your symptoms?
  • 13.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 05:29 PM
    If I do mdconnect from MM then I get the following:
  • 14.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 05:42 PM
    On the MD, what is the output of:
  • 15.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 05:48 PM
    CLIENT-CERT USER ROLE STATUS REVOCATION CHECKPOINT Max-concurrent-sessions PATH
  • 16.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 05:50 PM
    When you type "show switches" on the MM, is this MD listed there?
  • 17.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 05:53 PM
    Yes, we have 20 MDs on the MM all show up and all have the same issue.
  • 18.  RE: AOS8 mdconnect
    Posted Oct 11, 2019 06:32 PM
    Okay, on the MD, type this:
    show log all | include cert_dwnld
    See if there are any cert_dwnld errors.
  • 19.  RE: AOS8 mdconnect
    Posted Oct 14, 2019 09:13 AM
    This is all that shows on the MD
    Sep 29 13:11:45 cert_dwnld[4290]: PAPI_Send: To: 7f000001:8212 Type:0x4 Timed out.
  • 20.  RE: AOS8 mdconnect
    Posted Oct 16, 2019 10:06 AM
    I opened a TAC case and they were able to resolve the issue by changing SSH Authentication from User credentials to Both.
    This is found on the MD>Configuration>System - Admin Authentication Options.
    Thanks everyone for your help!
