Developer
AOS8 Postman collection
This thread has been viewed 61 times
  • 1.  AOS8 Postman collection
    Posted Jul 12, 2021 12:44 AM
    it seems no guys post postman collection about AOS8, I made one which includes collection and environment.
    some notes:
    1.You need to change the password for the login request.
    2.you need to change all the IP addresses in the url.
    3. you need to import the environment file before you run the requests.
    4.it is generated by a standalone controller, for mm/md architect, you may need to change the config_path in the url.
    5.the import part is in the login request, you may see "pm.environment.set('SESSION', pm.cookies.get('SESSION'))", basically it is used to get the sessionID, then pass it to environment parameter.
    download here. k1z2/Aruba_AOS8_Postman_COLLECTION
    GitHub remove preview
    some notes: 1.You need to replace the password for the login request. 2.you need to replace all the IP addresses in the url. 3. you need to import the environment file attached as well. 4.it is generated by a standalone controller. For mm/md architect, you may need to change the config_path in the url.
    View this on GitHub >
    thanks, let me know any problems.
    Kevin Zhu
  • 2.  RE: AOS8 Postman collection
    MVP GURU
    Posted Jul 12, 2021 06:19 AM
    Thanks Kevin !
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: AOS8 Postman collection
    Posted Dec 09, 2021 06:31 AM
    Very informative and useful article for beginners!
    Luise Johnson
  • 4.  RE: AOS8 Postman collection
    Posted Sep 28, 2021 12:09 PM
    Several comments have been deleted. All were relevant. Why the deletions?
    Michael Price
  • 5.  RE: AOS8 Postman collection
    Posted Dec 02, 2021 07:11 AM
    This repository contains workflows using the AOS-CX Ansible Collection.
    Luise Johnson
