AOS8 "show ap-group"
  • 1.  AOS8 "show ap-group"
    Posted Jul 10, 2018 10:46 AM
    I'm in the process of setting up an AOS8 cluster. Running 8.2.1.1. Trying to tweak some of the RF settings, I want to look at the AP groups from the console. When I do a "show ap-group" I do not see my AP groups. If I use "show ap-group ?" it lists my groups but I can never seem to get at them. Am I missing something?
    -Mike
  • 2.  RE: AOS8 "show ap-group"
    Posted Jul 10, 2018 11:03 AM
    Make sure you are under the correct folder
    Sent from Mail for Windows 10
  • 3.  RE: AOS8 "show ap-group"
    Posted Jul 10, 2018 11:46 AM
    I've tried it under every folder.
  • 4.  RE: AOS8 "show ap-group"
    Posted Jul 10, 2018 12:42 PM
     Typing "show configuration node-hierarchy" will show you all of your folders.
    Alternatively, you can "cd" to the name of one of your controllers, then type "mdc" to get into that controller.  You can then type "show ap-group" to see all of your groups from the perspective of that controller.
  • 5.  RE: AOS8 "show ap-group"
    Posted Jul 10, 2018 12:49 PM
    Never used the mdconnect before. It returns the following error:
    (ArubaMM-VA) [00:1a:1e:03:fb:00] #mdc
    Redirecting to Managed Device Shell
    Permission denied, Wrong UserName or password
    Exiting Managed Device Shell
    Do I need to configure something for it to work?
  • 6.  RE: AOS8 "show ap-group"
    Posted Jul 10, 2018 02:10 PM
    Are your controllers online? When you type "show switches" do you see your controllers?
  • 7.  RE: AOS8 "show ap-group"
    Posted Jul 10, 2018 02:31 PM
    Yes. Both my MM and MD are online and config up to date.
  • 8.  RE: AOS8 "show ap-group"
    Posted Jul 10, 2018 02:33 PM
    You can do the show configuration effective directly from the MC
  • 9.  RE: AOS8 "show ap-group"
    Posted Jul 10, 2018 03:21 PM
    A couple of commands you can use:
    (MM) [US-CONTROLLER-GROUP] #show switches
    All Switches
    IP Address IPv6 Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    192.168.1.108 None MM Building1.floor1 master ArubaMM-VA 8.2.1.1_65265 up UPDATE SUCCESSFUL 0 453
    192.168.1.141 None BOSTON-MC-1 Building1.floor1 MD Aruba7005 8.2.1.1_65265 up UPDATE SUCCESSFUL 0 453
    192.168.1.142 None BOSTON-MC-2 Building1.floor1 MD Aruba7005 8.2.1.1_65265 up UPDATE SUCCESSFUL 0 453
    (MM) [mynode] #show configuration node-hierarchy
    Configuration node hierarchy
    Config Node Type Name
    / System
    /md System
    /md/REMOTE-CONTROLLERS Group
    /md/REMOTE-CONTROLLERS/ Device RAPS-MC-1
    /md/US-CONTROLLER-GROUP Group
    /md/US-CONTROLLER-GROUP/BOSTON-CONTROLLER-GROUP Group
    /md/US-CONTROLLER-GROUP/BOSTON-CONTROLLER-GROUP/ Device BOSTON-MC-1
    /md/US-CONTROLLER-GROUP/BOSTON-CONTROLLER-GROUP/ Device BOSTON-MC-2
    /mm System
    /mm/mynode System
    (MM) [mynode] #cd /md/US-CONTROLLER-GROUP
    (MM) [US-CONTROLLER-GROUP] #show configuration effective | begin ap-group
    ap-group "BUILDING-A"
    virtual-ap "8021X-VAP"
    virtual-ap "GUEST-VAP"
    dot11a-radio-profile "11A-RADIO-PROFILE"
    dot11g-radio-profile "11G-RADIO-PROFILE"
    ap-system-profile "MD1-AP-SYS-PROFILE"
    regulatory-domain-profile "BUILDING-A-DOMAIN-PROFILE
  • 10.  RE: AOS8 "show ap-group"
    MVP EXPERT
    Posted Jul 10, 2018 06:33 PM
    Possible you entered the command from the mobility master and not from the managed device itself.
    To connect to the managed device use the mdconnect command from the master or directly ssh to the managed device
    # /md/.......
    # mdconnect
  • 11.  RE: AOS8 "show ap-group"
    Posted Jul 11, 2018 08:34 AM
    From my MM I entered the following (the MAC address being my MD)...
    (ArubaMM-VA) [00:1a:1e:03:fb:00] #mdconnect
    Is it really the case that I have to login to the MD in order to see my AP groups...which I manage from the MM?
  • 12.  RE: AOS8 "show ap-group"
    Posted Jul 11, 2018 08:37 AM
    You can type:
    show configuration effective <name of controller> | begin ap-group
  • 13.  RE: AOS8 "show ap-group"
    Posted Jul 11, 2018 08:45 AM
    @cjoseph wrote:
    You can type:
    Understood...I'm just looking for some of the functionality from AOS6. Running "show ap-group" on my AOS6 master yields simple results and I can show details with "show ap-group <name>" instead of having to wade through configs. AOS8 just doesn't seem that friendly to console use.
  • 14.  RE: AOS8 "show ap-group"
    Posted Jul 11, 2018 09:09 AM
    I don't know why MDC does not work, but you can also SSH into your controller and type "show ap-group" to see what groups are there.  AOS 8 is hierarchical and most the the configuration should be configured at the container level, but you want to look at the resulting configuration at the controller level just in case something was defined at the controller level, as well.
    Please see the videos here:  https://www.youtube.com/playlist?list=PLsYGHuNuBZcatGA1POy6iVpVlDTLYzNFE  for more information.
