Network Management
AOS8.0 and CPPM config mpsk case
  • 1.  AOS8.0 and CPPM config mpsk case
    Posted Jul 09, 2020 05:37 AM
    Hi all, I'm implementing an mpsk requirement and was hoping I could get help, I'm not very good at configuring it. Is there a configuration template I can follow? Users want different policies to be issued for different psk.
  • 2.  RE: AOS8.0 and CPPM config mpsk case
    Posted Jul 09, 2020 07:44 AM
    What are you using for RADIUS?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: AOS8.0 and CPPM config mpsk case
    Posted Jul 09, 2020 07:54 AM
    Thank you for your response.
    Use of CPPM
    Here is the configuration of cppm, but I'm a little confused as to why it's configured this way, if I want to use different psk to send down different policies, can I only change the role?
    微信截图_20200709194853.png微信截图_20200709194853.png微信截图_20200709194853.png微信截图_20200709194853.png微信截图_20200709194853.png微信截图_20200709194853.png
  • 4.  RE: AOS8.0 and CPPM config mpsk case
    Posted Jul 09, 2020 08:59 AM
    A role is selected during device registration. This is also where the device's unique pre-shared key is generated. The built-in service template just maps the logic from device registration.
    You shouldn't be using [Employee] tag/role for every device. Use specific roles like "Media Player" or "Printer", etc.
  • 5.  RE: AOS8.0 and CPPM config mpsk case
    Posted Jul 10, 2020 04:58 AM
    hi,Thanks for the reply, I tried to post the emplyee role last night but it didn't work, I configured the same in the controller too! of the role; do you have better documentation of the implementation? Is it easy to share?
  • 6.  RE: AOS8.0 and CPPM config mpsk case
    Posted Jul 10, 2020 09:09 AM
    Sorry I don't understand.
    In the MPSK wizard, you will be asked to select roles (tags) that will be available during device registration. You will then be asked to map those tags to user roles that need to exist on the Aruba controller.
    Example:
    CPPM Role/Tag = Media Player
    Aruba User Role = media-player
  • 7.  RE: AOS8.0 and CPPM config mpsk case
    Posted Jul 12, 2020 06:01 AM
    Thanks for the reply, I will do the experiment to verify.
