AOS8.2 7210 standalone with high memory usage all times.
  • 1.  AOS8.2 7210 standalone with high memory usage all times.
    Posted Nov 01, 2018 05:01 AM
    my controller is 7210 AOS8.2  AP305 : 25 APs  and 80 clients
    total memory 5.3G
    availiable 102MB
    Is it normally with high memory usage or how can I reduce it?
  • 2.  RE: AOS8.2 7210 standalone with high memory usage all times.
    Posted Nov 01, 2018 06:21 AM
    What is the exact version/build of AOS 8.2 that you are running?
    There were multiple patches release since the initial 8.2.0.0 release back in 2017.
    I would recommend opening a TAC case to analyze this. Make sure to follow the guidelines listed in this doc and send in the tech-support logs right away: https://support.arubanetworks.com/Portals/0/uploads/614/Aruba_Networks_TAC_Case_Guideline.pdf
    That being said there is a commands on the CLI that displays detailed memory utilization:
    show memory debug verbose
  • 3.  RE: AOS8.2 7210 standalone with high memory usage all times.
    Posted Nov 01, 2018 08:36 AM
    controller version 8.2.0.2 Build 62929
    and attached file from "show memory debug verbose".
    Attachment(s)
    txt
    AOS8.2_HighMem.txt   196 KB 1 version
  • 4.  RE: AOS8.2 7210 standalone with high memory usage all times.
    Posted Nov 01, 2018 08:57 AM
    Among other processes, your fw_visibility process is consuming some amount of memory:
    Memory Usage (USS, PSS, RSS in  Kbytes) of All processes on the system
      PID User     Command                         Swap      USS      PSS      RSS
     3953 root     /mswitch/bin/lagm               2624   955008   955623   962688
     3960 root     /mswitch/bin/licensemgr          576   277184   277508   283456
     4228 root     /mswitch/bin/fw_visibility         0   266752   267838   303552
     3889 root     /mswitch/bin/gsmmgr                0   241024   262135   308608
     3942 root     /mswitch/bin/fpapps               64   144448   146414   156736
     3864 root     /mswitch/bin/arci-cli-helpe      128   113856   115201   123904
    Are you doing any excessive DPI with your controller?
    As mentioned TAC should be your No. 1 go-to resource to identify the root cause of this. Otherwise, you would be only guessing why this happens.
    Independently from that, 8.2.2.1 has recently earned the Conservative Release (CR) tag and therefore I recommend looking at upgrading your controller to this release: https://www.arubanetworks.com/support-services/end-of-life/arubaos-software-release/
  • 5.  RE: AOS8.2 7210 standalone with high memory usage all times.
    Posted Nov 01, 2018 09:07 AM
    Please try upgrading to ArubaOS 8.2.2.1.  Like @
    Attachment(s)
  • 6.  RE: AOS8.2 7210 standalone with high memory usage all times.
    Posted Nov 01, 2018 11:45 AM
    At firewall menu, I checkbox to enable firewall visibility and deep packet inspection other setting is default.
    From you are recommend 8.2.2.1, If I bring upgrade to  8.3.0.3 66538 can let do it?
    thankyou.
  • 7.  RE: AOS8.2 7210 standalone with high memory usage all times.
    Posted Nov 01, 2018 12:04 PM
    8.2.2.1 is the safest upgrade path to fix your issue.
    8.3.0.4 will be out soon and that would probably be more recommended than 8.3.0.3.
  • 8.  RE: AOS8.2 7210 standalone with high memory usage all times.
    Posted Nov 02, 2018 10:56 AM
    Now i upgrade to 8.2.2.1 high memory is solved.
    Memory (Kb): total: 5184256, used: 1387456, free: 3796800
    thankyou for all supports.
  • 9.  RE: AOS8.2 7210 standalone with high memory usage all times.
    Posted Nov 02, 2018 10:57 AM
