AOS8.3 Unable to mdconnect
  • 1.  AOS8.3 Unable to mdconnect
    Posted Mar 19, 2019 02:27 PM
    (MMaster) [mac-address] #mdconnect
    Redirecting to Managed Device Shell
    Permission denied: wrong username or password
    Where do I set this? I'm not sure why I'm getting this error and want configuration access on the md.
  • 2.  RE: AOS8.3 Unable to mdconnect
    MVP EXPERT
    Posted Mar 19, 2019 02:40 PM
    First. All configuration need to be done from de mobility master.
    Second. Check your priviledge level of your user account on the mobility master.
  • 3.  RE: AOS8.3 Unable to mdconnect
    Posted Mar 19, 2019 06:07 PM
    What version of AOS 8.3 are you running? Assuming not a beta version, then I would agree with MKK and suggest checking permissions for your mgmt-user account that you used to connect to the MM.
  • 4.  RE: AOS8.3 Unable to mdconnect
    Posted Mar 20, 2019 12:38 PM
    Thank you for the responses. I do understand confguration happens at the MM. However, I was running into a command that was telling me to run mdconnect. When I ran it I was getting the error.
    I don't see a role on the upper-right and I logged in with the admin account but still get the error when doing mdconnect.
  • 5.  RE: AOS8.3 Unable to mdconnect
    MVP EXPERT
    Posted Mar 20, 2019 01:35 PM
    My bad, the upper-cornet thing is in the Clearpass GUI.
    I dont no why you got a connection error when use default admin account.
