Wired Intelligent Edge
AOSCX - Shut does not remove power from the port?
This thread has been viewed 27 times
  • 1.  AOSCX - Shut does not remove power from the port?
    Posted Feb 26, 2020 04:11 PM
    Hi there,
    I'm currently testing ArubaCX switch and face the following "behaviour":
    - If I shut a port, the devices are still powered
    - I can only remove power if I do a "no link-poe"
    The problem here is that a "bounce" CoA will not remove power from a device. If I have a Computer behind a Phone, and I use dhcpv4snopping, the device will not re-ask dhcp because it will not sense the link went down. Because the phone never powers off.
    Is this an expected behavior? All my other switches, Aruba or non Aruba, always shut down the power on "shut".
  • 2.  RE: AOSCX - Shut does not remove power from the port?
    Posted Feb 26, 2020 05:07 PM
    so as you know we have always-on PoE enabled by default for 6300/6400s, which could produce this behaviour
    show power-over-ethernet will display if its enabled.
  • 3.  RE: AOSCX - Shut does not remove power from the port?
    Posted Feb 27, 2020 04:59 AM
    Always On PoE is disabled.
  • 4.  RE: AOSCX - Shut does not remove power from the port?
    Posted Feb 27, 2020 08:32 AM
    More specifics please: What firmware release and which aruba switch ?
  • 5.  RE: AOSCX - Shut does not remove power from the port?
    Posted Feb 27, 2020 10:06 AM
    Switch. 6300M.
    v. 10.04.0030
    "no power-over-ethernet always_on " set for all modules.
  • 6.  RE: AOSCX - Shut does not remove power from the port?
    Posted Feb 27, 2020 10:23 AM
    Please respond with the output from:
    show power-over-ethernet brief
    Yes, I believe your earlier interpretation of what you gleaned from your previous research.
  • 7.  RE: AOSCX - Shut does not remove power from the port?
    Posted Feb 27, 2020 12:08 PM
    Good day!
    This is expected. We use same pair to carry data and poe.
    • Shutdown is for data
    • No power-over-ethernet is for poe
    Same is true in case of AOS-Switches.
    By default PoE is enabled on all poe capable ports or LC.
    If you want to remove PoE please use "No power-over-ethernet", if you want to shutdown data, then use shutdown.
    Details below:
    GOCRAZY# show power-over-ethernet 1/4/26
    Status and Configuration Information for port 1/4/26
    Power Enable : Yes PD signature : N/A
    PoE Port Status : searching PD Type : N/A
    Alloc-by Configured : usage Alloc-by Actual : usage
    User Profile Priority : N/A Port Config Priority : Low
    Port Priority : low Pre-std Detect : Disabled
    PD Requested Class : N/A PSE Assigned Class : N/A
    Fault Status : None User set Assigned Class : class4
    PoE Counter Information
    Over Current Cnt : 0 MPS Absent Cnt : 1
    Power Denied Cnt : 0 Short Cnt : 0
    Power Information
    PSE Voltage : 0.00 V PSE Reserved power : 0.00 W
    PD Current Draw : 0.00 A PD Power Draw : 0.00 W
    PD Average Power Draw : 0.00 W PD Peak Power Draw : 0.00 W
    LLDP Information
    MED Override : Disabled
    MED Priority : N/A
    PSE TLV Configured : dot3/med
    PSE TLV Sent Type : N/A
    PD TLV Sent Type : N/A
    PSE Allocated Power Value: 0.00 W
    PD Requested Power Value : 0.00 W
    GOCRAZY#
    GOCRAZY(config)# interface 1/4/26
    GOCRAZY(config-if)#
    GOCRAZY(config-if)# no power-over-ethernet
    GOCRAZY(config-if)#end
    GOCRAZY#
    Power Enable : No PD signature : N/A
    PoE Port Status : disabled PD Type : N/A
    Over Current Cnt : 0 MPS Absent Cnt : 0
    Power Information
    LLDP Information
    MED Priority : N/A
    Thank you,
    Yash
  • 8.  RE: AOSCX - Shut does not remove power from the port?
    Posted Feb 28, 2020 05:32 PM
    Can I override this so that Shut and (Clearpass) Port Bounce turns off-on power of the port?
    Need this to support clients connected to my Polycom phones.
  • 9.  RE: AOSCX - Shut does not remove power from the port?
    Posted Feb 29, 2020 05:07 AM
    Happy weekend!
    Good request. AFAIK, currently not supported.
    This is right enhancement feature, using AOS-CX REST API this should be possible. Please send your request to account team.
    Yash
