Developer
aoscx_vlan slow loop
This thread has been viewed 26 times
  • 1.  aoscx_vlan slow loop
    Posted Feb 16, 2021 10:09 AM
    Hi all,
    I have been working with the AOS-CX role for a while and decided to see if I could improve the speed of administration of  VLANs with aoscx_vlan.  Currently I am have them all in a vars file like:
    vlans:
      - {vlanid'4'vlanname'vlan0004'vlanadminstate'up'vlanstate'create'}
      - {vlanid'8'vlanname'vlan0008'vlanadminstate'up'vlanstate'create'}
      - {vlanid: '399', vlanname: 'vlan4000', vlanstate: 'delete'}
      - {vlanid: '4000', vlanname: 'vlan4000', vlanadminstate: 'up', vlanstate: 'create'}
    and the task is:
      - name: Create VLANs
        aoscx_vlan:
          vlan_id"{{ item.vlanid }}"
          name"{{ item.vlanname }}"
          admin_state"{{ item.vlanadminstate | default(omit)  }}"
          state"{{ item.vlanstate }}"
        loop"{{ vlans | flatten (levels=1) }}"
    My vars file has about 80 vlans defined and takes about 50 seconds per switch to run. Not terrible, but you can see where this will be a bottleneck once getting past a handful of switches.
    I did a bit of research and found a few Ansible config changes to try, it saved about 1 second off the time. Found other suggestions that were module specific which the aoscx_vlan module does not support, aggregate (eos module), src + jinja template (nxos module).
    Any suggestions to improve this workflow?
    Don Rhodes
  • 2.  RE: aoscx_vlan slow loop
    MVP GURU
    Posted Feb 16, 2021 10:48 AM
    Hi Don,
    I think, it is better to ask directly on Ansible AOS CX github
    What latency do you have to the switch ? (on the same LAN ?)
    do you have look log to see what it is make ?
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: aoscx_vlan slow loop
    Posted Feb 22, 2021 07:16 AM
    Typical latency is ~0.4ms.  For a log, are you talking about a -vvvv output or a log from the switch?
    Don Rhodes
  • 4.  RE: aoscx_vlan slow loop
    MVP GURU
    Posted Jun 09, 2021 04:26 PM
    Yes,
    I think there is a also some timer on the switch when you add a vlan...
    (and i think it is not yet possible to add multiple vlan on the same time/POST API request)
  • 5.  RE: aoscx_vlan slow loop
    Posted Jun 07, 2021 10:43 AM
    for (Iterator<String> i = someIterable.iterator(); i.hasNext();) {
    String item = i.next();
    System.out.println(item);
    Note that if you need to use i.remove(); in your loop, or access the actual iterator in some way, you cannot use the for ( : ) idiom, since the actual iterator is merely inferred.
    As was noted by Denis Bueno, this code works for any object that implements the Iterable interface.
    Prepaid Gift Balance
    Henke Michel
