AP 103 console port
  • 1.  AP 103 console port
    Posted May 06, 2014 12:56 PM
    Hello
    It seems that the new ap 103 does not have console port(or at least i dont see it on the picture of the AP 103)
    but on the datasheet it says
    Serial console interface (proprietary; optional adapter
    cable available)
    what does this mean??
    Cheers
    Carlos
  • 2.  RE: AP 103 console port
    Posted May 06, 2014 01:07 PM
    Carlos,
    The AP-103 does have a console port but it uses a special 4 pin adapter like the RAP-3. The SKU for the adapter is AP-CBL-SER.
    Here is a underside image of the AP 103 from the installation guide.
    Best regards,
    Madani
  • 3.  RE: AP 103 console port
    The AP 103 console port is between the Ethernet and DC power port when looking at the rear. It has a plastic cover that you can just see if you look closely. The adapter is sold separately.
  • 4.  RE: AP 103 console port
    Posted May 06, 2014 01:09 PM
    IT is possible to buy one and use it on different AP 103
    I mean just for troubleshooting purpuses....
    If i need to console it, i would go and  put the console port, and went i finish i would remove it? i mean instead of buying one for each AP.
    Cheers
    Carlos
  • 5.  RE: AP 103 console port
    Posted May 06, 2014 01:17 PM
    Absolutely, you only need to connect the adapter when you're troubleshooting and you only need one.
    Madani
  • 6.  RE: AP 103 console port
    Posted Jul 07, 2014 10:29 AM
    while pricelist says 75dollar for this crap cable , im about to build myself like on the old AP65 with the SPOE cable , anyone has some hint which pins are connected how on that crap cable ?
    i really wonder why aruba produces such a port and doesnt keep on the old-school console port style like on newer AP/RAP's ...
    anyways... someone has some hint , perhaps some eBay cable which does the job ?
    regards
    ben
  • 7.  RE: AP 103 console port
    Posted Jul 07, 2014 10:31 AM
  • 8.  RE: AP 103 console port
    Posted Jul 07, 2014 10:32 AM
    I bealive they did that to drop the prices of the APS(well one of the things they did)... why do you think the AP 103 is at that price???
    Cheers
    Carlos
  • 9.  RE: AP 103 console port
    Posted Jul 07, 2014 10:55 AM
    did i mention AP103 is 75dollars ? im talking about the cable.
    regards
  • 10.  RE: AP 103 console port
    Posted Jul 07, 2014 10:59 AM
    I was asnwering this comment:
    "i really wonder why aruba produces such a port and doesnt keep on the old-school console port style"
    Cheers
    Carlos
  • 11.  RE: AP 103 console port
    Posted Jul 07, 2014 11:29 PM
    It drops the price for the AP to just pin a header on the PCB instead of using the jack, considering console port use is a rather specialist scenario.  Seen it done on other vendor's low-end units as well.  Just be glad it's RS232 and not a JTAG.
  • 12.  RE: AP 103 console port
    Posted Sep 03, 2014 05:59 AM
    now if I don't have this special cable how I would Reset the AP-103 ??
  • 13.  RE: AP 103 console port
    Posted Sep 03, 2014 09:54 AM
    ADAMS,
    On the underside, there is a reset button. To reset the AP:
    1. Power off the AP.
    2. Press and hold the reset button using a small, narrow object, such as a paperclip.
    3. Power-on the AP without releasing the reset button. The power LED will flash within 5 seconds.
    4. Release the reset button.
    5. The power LED will flash again within 15 seconds indicating that the reset is completed. The AP will now continue to boot with the factory default settings.
    To locate the reset button, you can refer to the AP-103 Installation Guide.
    http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=13909
    Best regards,
    Madani
  • 14.  RE: AP 103 console port
    Posted Oct 16, 2014 04:26 AM
    hi,
    in fact this is kind of standard. I've found some pics of someone who has that cable and opened it up for us. Those showed me that I was right.
    The Serial Connector on the AP103 (and oviously on all others that use the same cable) is just a standard ttl serial connector.
    The 70$ (!) Cable contains nothing more than a DB9 Connector + the required circuit for converting ttl to something a standard RS232 can handle.  This is just a MAX232 or compatible IC + 4 Capacitors, the DB9 Connector and the cable for the Pin Header on the AP.
    The Pic of the Plugs and the Datasheet of the MAX232 enables you to find out the pinout:
    Imagine the Plug on AP sid like this
    black     1   -------------+  Vcc
    black     2               ----|  TX
    white     3               ----|  RX         this side connects to Pin Header on AP
     red        4  -------------+ GND
    (without any warranty, so use on your own risk)
    You will need to do what Aruba does if you want to connect that directly to a serial port since this requires different ttl levels.
    You can also connect directly through some FDDI-to-usb because those can handle this directly.
    I just don't understand why that Cable is so expensive with Aruba.
    Sorry Aruba you have to admit that once you sold some of these cables someone will find this out!
    Sebastian
  • 15.  RE: AP 103 console port
    Posted Oct 16, 2014 06:16 AM
    $70 is list price. I'm sure if you work with your Aruba team you will pay much less than that (if anything at all).
  • 16.  RE: AP 103 console port
    Posted Oct 16, 2014 06:40 AM
    We got our 25 AP-103s via a reseller and they said they hat to order that cable and pay EUR 80 for it...
    However usually you don't need it at all since you manage via virtual controller or airwave. But we used it for diagnostics during the installation of our systems. We even used it to see why one AP 103 didn't come back after firmware upgrade...
    For these purposes it may be useful :)
    This is also why we would like to have the possibillity to access the serial interface...
    cheers
    Sebastian
  • 17.  RE: AP 103 console port
    Posted Oct 04, 2015 06:15 AM
    I agree the price for the cable is high. The components are about $5, sure charge $15 or 20, no one would care, but $70 is a bit to much. If it's handling and logistics that cost, why not sell 2 or 3 in a pack for the same price? Todays pricing makes the cables rare and if one fails you are unlikely to have an extra to use right away. This is bad for both technicians and the customers.
    Anyway, you might be interested in this post of mine.
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/AP-CBL-SER-Cable-Diagram/m-p/248585#M53805
  • 18.  RE: AP 103 console port
    Posted Oct 05, 2015 01:21 PM
    No disagreement with the comment that the list price for this cable/converted is high.
    But, it's not an off-the-shelf item for us, and volume is relatively low.
    If you're an Aruba customer or partner and need this cable, I'm sure the Aruba sales rep can cut you a deal (i.e. high discount) for this item.
  • 19.  RE: AP 103 console port
    Posted Oct 06, 2015 03:37 AM
    I agree, the price is not really a big issue in practice with partner discounts, it's just annoying to pay so much for so little. The reason i had a go with the USB-TTL adapter was after reading the response from Aruba: "You cant make your own cable since its an active adapter". As a tech i gladly took the challange, and it was way easier than expected. :)
