AP-104 compatible controller ?
  • 1.  AP-104 compatible controller ?
    Posted Mar 21, 2018 06:52 PM
    have a few AP-104 that i want to start using.
    as far as i understand, i need a controller for this.
    i have the ability to buy a 3400 controller.
    2 questions ;
    - is the 3400 a suitable controller for AP-104 ?
    - do i need software with this controller and/or licensing for use/configuration ?
  • 2.  RE: AP-104 compatible controller ?
    Posted Mar 22, 2018 12:56 AM
    The AP-104 can work with the 3400 controller.
    Yes, you will need software, which requires the controller to have active support.
    Yes, you need licensing to support the APs.
  • 3.  RE: AP-104 compatible controller ?
    Posted Mar 22, 2018 02:42 PM
    thank you kindly for your answer.
    curious what amount of money is involved here for 4-5 AP's ?
    i understand this is your way to make money, but i doubt to go into this route.
