AP 104 ports
  • 1.  AP 104 ports
    Posted Jan 20, 2014 09:23 AM
    For AP 104, the 3 antenna ports are dual band and so I assumed one could plug antenna in any port. I hear that is incorrect and the port have to be configured on the controller for either 2.4 or 5. Is that correct? Thanks
  • 2.  RE: AP 104 ports
    Posted Jan 20, 2014 10:25 AM
    The AP-104 has 4 antenna ports; 2 for each radio.    They are assigned as follows:
    R0/A0 - Radio 0 (5GHz), chain 0
    R0/A1 - Radio 0 (5GHz), chain 1
    R1/A0 - Radio 1 (2.4GHz), chain 0
    R1/A1 - Radio 1 (2.4GHz), chain 1
    R0 = Radio 0 (5.0GHz)
    R1 = Radio 1 (2.4GHz)
    A0 = Antenna 0
    A1 = Antenna 1
  • 3.  RE: AP 104 ports
    Posted Jan 21, 2014 12:11 PM
    AP104 have 4 antennas port, if you are having 3 it should be AP224, AP114 or AP134. Please do check again.
