AP 105
  • 1.  AP 105
    Posted Dec 10, 2013 04:02 PM
    My AP work perfectly the last week.
    Today, the AP pwr led flash green and the enet led flash red all the time. I try to enter in console mode for a reset factory but I see nothing to my screen. I try with a other AP and its work perfectly.
    This is possible my AP is broken? Can I do a hard reset?
    Thank you
  • 2.  RE: AP 105
    Posted Dec 10, 2013 04:26 PM
    Try plugin it into another switch port or try another patch cable .
    If this does work and you can't see anything then you may have to RMA the ap
  • 3.  RE: AP 105
    Posted Dec 10, 2013 04:27 PM
    I try everything you telle me and nothing change.
    What is RMA?
  • 4.  RE: AP 105
    Posted Dec 10, 2013 06:22 PM
    It depends on the type of support you have purchase but you can call Aruba support and get a replacement for your faulty AP, please read the information on this link it provides better information about that:
    http://www.arubanetworks.com/support-services/aruba-support-program/
  • 5.  RE: AP 105
    Posted Dec 11, 2013 10:15 AM
    Just open up a case.  Our APs have a lifetime warranty.
  • 6.  RE: AP 105
    Posted Dec 16, 2013 03:53 PM
    Where I have to go to return my AP?
    I send my question to aruba site, but I don't receive any answer.
  • 7.  RE: AP 105
    Posted Dec 16, 2013 04:02 PM
    Send an email to support@arubanetworks.com with the serial and model
    numbers.
