Hi I have an AP 105 trying to add it to the network we use an aruba controller 3200 XM. I plugged the network cable into the console port the power light flashes green slowly and the Enet light blinks amber about every 2 seconds. The AP shows up in the controller at least its MAC address does and thats it.
Is that the first AP105?
On the commandline of the controller, type "show ap database" to see if you can see the access point.
No we have 21 AP's on the network all of them are IAP's this will be the first non IAP on the network. Not sure about the cmd line i'm using the web gui. In there is does show the MAC address.
Can you send a screenshot of what you are seeing?
Sure the top one is it.
Looks like there are no radios up on that (no channel). Did you do any device-specific configuration for that AP?
Not sure what you mean by this.
Please open a support case to see why it is not broadcasting.
Ok I connected to the ENET port instead of the console port and all is good thank you for all your help.
