AP-105 and AP-215 installation
  • 1.  AP-105 and AP-215 installation
    Posted Mar 02, 2015 10:15 AM
    Can we are install AP-105 and AP-215 on the wall instead of mounting on the the ceiling? Will the coverage change a lot since they have omni directional antennas?
  • 2.  RE: AP-105 and AP-215 installation
    Posted Mar 02, 2015 11:10 AM
    Yes it will show a significant effect WRT coverage. you can control it some extent by using 'L' bracket and mount it to the wall.
    Please feel free for any further query on this.
  • 3.  RE: AP-105 and AP-215 installation
    Posted Mar 02, 2015 12:10 PM
    Hi
    AP105 and AP 275 are designed to be mounted in the ceiling, there are specific AP like AP 93H and AP103H wich are designed to wall mounting.
    so the best is to mount them in the ceiling, otherwise it is prefered to do a sitesurvey to confirm that it works !!
    Regards
