last person joined: 11 hours ago
AP 105 and LDAP integration
  • 1.  AP 105 and LDAP integration
    Posted Sep 25, 2013 06:10 PM
    I'm working with a customer evaluating some IAP-105's and they are wanting to test authentication using their Active Directory. They do not wish to install a Radius server at this time.  I do see where I can create a LDAP server under Security, but I seem to not get authenticated.  I have verified that I can connect with my supplied credentials regarding my server setup, but it appears that possibly the user credentials are getting rejected.  I have seen a few older articles pertaining to LDAP issues and wanted to know if anyone has this working or if there exists any good documentation/troubleshooting pertaining to this type of configuration.  I know Radius is the way to go, but I do not have this option at this time.
  • 2.  RE: AP 105 and LDAP integration
    Posted Sep 25, 2013 06:45 PM
    If you want to use LDAP for 802.1X for authentication, make sure you enable termination on the WLAN setup on the IAP.
  • 3.  RE: AP 105 and LDAP integration
    Posted Oct 14, 2013 07:17 AM
    HI,
    I have a problem with that too. LDAP authentication is working fine with mobile devices (Android, iOS), but is not working with laptops (Windows 7, Windows 8). I checked windows 7 and windows 8 configuration, and they work fine when i use LDAP authentication using Aruba Controller (against the same LDAP server). Problem is just with Aruba Instant AP.
    You can't select LDAP server if you don't enable termination
    Regards
