AP-105 as AirMonitor in 802.11ac deployment ?
  • 1.  AP-105 as AirMonitor in 802.11ac deployment ?
    Posted Mar 06, 2015 08:58 AM
    We started our migration to 802.11ac.
    Can I use the retired AP-105s as AirMonitors in our 802.11ac zones ?
    Is so, what would be the limitations ?
    TIA
  • 2.  RE: AP-105 as AirMonitor in 802.11ac deployment ?
    Posted Mar 06, 2015 10:35 AM
    the limitation would be that the air monitor will not be able to see this higher channel bandwidth data. you will be limited to 20mhz and 40 MHz only. for basic rogue detection it will be fine.
    it will also work just fine as a spectrum monitor
  • 3.  RE: AP-105 as AirMonitor in 802.11ac deployment ?
    Posted Mar 07, 2015 05:16 AM
    Edit.
  • 4.  RE: AP-105 as AirMonitor in 802.11ac deployment ?
    Posted Jul 20, 2018 01:51 AM
    I'd like to ask about using a 205 as an AirMonitor when there are 3xx AP's deployed.   Can a 205 be a suitable AM?   3xx wave 2 AP can do wider 160mh channels and MU-MIMO... I assume this could be an issue meaning the wider channel traffic cannot be properly observed by the 205.  I am also concerned that perhaps MU-MIMO traffic might be misinterpretted in some way?   Can i get some feedback on Aruba's take on this?  Thank you
  • 5.  RE: AP-105 as AirMonitor in 802.11ac deployment ?
    Posted Jul 24, 2018 05:14 PM
    Since this is not related to the AP-105 as the title suggests, it should be in a new thread for easier searching.
    The AP205 would be a better fit than the AP105. Ultimately, it depends on the types of incidents you are trying to protect against.
