AP-105 cannot associate with 3200XM Controller
  • 1.  AP-105 cannot associate with 3200XM Controller
    Posted Mar 27, 2012 11:00 AM
    Dear all, I am not an expert in configuring Aruba controllers, so my question may not be appropriate if you will.  I followed a video training and I applied that config as close as I could into my 3200XM which is my lab equipment.  I do have licenses loaded, but I can not end up seeing the AP on the controller.  Below is the config could you please help?  thanks
    Attached file opens with textpad, notepad
    #3200
    Attachment(s)
    zip
    Aruba3200XM.zip   4 KB 1 version
  • 2.  RE: AP-105 cannot associate with 3200XM Controller
    Posted Mar 27, 2012 11:51 AM
    is the access point on the same subnet as the controller?
    Is something supplying DHCP to the AP?
  • 3.  RE: AP-105 cannot associate with 3200XM Controller
    Posted Mar 27, 2012 11:52 AM
    I am plugging the AP on Port 1/1 which is on the native VLAN1, 172.16.0.254/24.
  • 4.  RE: AP-105 cannot associate with 3200XM Controller
    Posted Mar 27, 2012 11:54 AM
    Something needs to provide DHCP on that VLAN.  You need to create a DHCP scope on that controller so that the AP can get an ip address.   Go to Configuration> Network> IP > DHCP to create a DHCP scope in that range and enable the DHCP service.
  • 5.  RE: AP-105 cannot associate with 3200XM Controller
    Posted Mar 27, 2012 12:02 PM
    This is the management VLAN that is the default of the controller.  So at this point i am not sure how to do it.  thanks
  • 6.  RE: AP-105 cannot associate with 3200XM Controller
    Posted Mar 27, 2012 12:10 PM
    Go to configuration> Network > IP> DHCP Server.  Click on the enable checkbox to enable the DHCP server.  Next, Add a DHCP server pool and make the network 172.16.0.0 netmask 255.255.255.0 dns 8.8.8.8 and default gateway 172.16.0.254 and click on apply.
