AP-105 Command Line Configuration
  • 1.  AP-105 Command Line Configuration
    Posted Oct 24, 2012 10:36 AM
    Hey, I am trying to do a full Remote AP configuration on an AP-105 through a console connection but it never works.  I restarted an AP that was already configured, and interrupted the boot and captured the configuration that was on it.  Then It took a new AP and did set commands for all of the parmeters to duplicate the configuration, but the AP never comes up.  I assume I need to do something special with the ikepsk or pappasswd?
    apboot> print
    bootdelay=2
    baudrate=9600
    autoload=n
    boardname=Talisker
    bootcmd=boot ap
    autostart=yes
    bootfile=mips32.ari
    ethaddr=d8:c7:c8:ca:93:13
    name=Pilot-AP-93-12
    group=TEST-APGROUP
    master=10.146.243.50
    serverip=10.146.243.50
    a_antenna=0
    g_antenna=0
    ikepsk=A543C3DF489A10FFF6F105BB3C96EFC1FF6306F935CC1BE8092B2316FB8AEE3D
    papuser=vzw-rap
    pappasswd=89769C8CFF9A1E4627C6692E3D755E666A26FF6300C26149E0346C96F3DE3ECB
    usb_type=0
    auto_prov_id=0
    is_rmp_enable=0
    remote_ap=1
    priority_ethernet=0
    priority_cellular=0
    cert_cap=0
    mesh_role=0
    installation=0
    mesh_sae=0
    start_type=cold_start
    stdin=serial
    stdout=serial
    stderr=serial
    ethact=eth0
  • 2.  RE: AP-105 Command Line Configuration
    Posted Oct 24, 2012 11:18 PM
    I would simply NOT put in the lines below:
    papuser=vzw-rap
    Enter the AP 105s wired mac address into the RAP whitelist on the controller, and you should be good to go.
    ikepsk and pappasswd are individual for each AP.
  • 3.  RE: AP-105 Command Line Configuration
    Posted Oct 24, 2012 11:22 PM
    Thank you for the response.
    Actually ikepsk and pappasswd are the same across our enterprise.  So if there was a way for me to tell the AP what it is, I wouldn't have to touch the controller at all.
  • 4.  RE: AP-105 Command Line Configuration
    Posted Oct 24, 2012 11:27 PM
    That is the issue.  Even for the same PSK and password, it is DIFFERENT for each access point.
    That is so that someone cannot just find your access point or your PSK on an abandoned access point, put your parameters into their AP and connect to your network.  You need to put those parameters in via the controller's provisioning mechanism.
