Hello Every one
Is it possible to run AP 105 as RAP
and if it possible what is the configuration to deploy AP 105 as rap on controller & AP
The procedure for deploying an AP-105 as a RAP is identical to configuring other access points as remote APs. Have you looked in the user guide or in the knowledgebase about Remote AP information?
Hiii cjoseph
Thanks for your fast replay no i didnot look in deplyment guide how i can find it
is it required to directly connected to AP to configure is as RAP ??
The Remote AP Validated Reference design guide here: http://community.arubanetworks.com/t5/Validated-Reference-Design/Aruba-Remote-Access-Point-RAP-Networks-Validated-Reference/ta-p/155612 will have the answers to your questions.
The access point does not have to be physically connected to the controller, but it must be provisioned while it has connectivity to the controller.
