AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
  • 1.  AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 04, 2014 02:37 PM
    Sorry, I'm new to this and having an issue setting up AP-105 wireless access points.
    I have set a vlan for the 800 controller and can get to the controller configuration interface. The AP's boot and get an IP address and see the controlller via ADP but do not show up in the Controller interface. I'm probably missing something simple. Any assistance would be appriciated.
  • 2.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 04, 2014 04:04 PM
    Please post the console output from the AP when you are booting it up.
  • 3.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 03:24 AM
    Here is the output the controller has a very old OS
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU: AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM: . 128 MB
    POST1: mem 0 mem 1 mem 2 mem 3 passed
    Copy: ....    done
    Flash: 16 MB
    PCI: scanning bus 0 ...
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
    01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
    Net: eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot: 2  1  0
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    eth0 up: 100 Mb/s full duplex
    DHCP broadcast 1
    checksum bad
    DHCP broadcast 2
    DHCP IP address: 192.168.1.9
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.168.1.1
    DHCP DNS server: 192.168.1.1
    DHCP DNS domain:
    ADP multicast 1
    Controller address: 192.168.1.99
    Using eth0 device
    TFTP from server 192.168.1.99; our IP address is 192.168.1.9
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: *####################################################
    done
    Bytes transferred = 3353836 (332cec hex)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Automatic boot of image at addr 0x02000000 ...
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (3284968 bytes)
    Clearing .bss @ 0x81121ff0 (16 bytes)
    Loading .data @ 0x81122000 (32 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing..............................
    ü
    Aruba Networks
    ArubaOS Version 3.4.3.2 (build 25931 / label #25931)
    Built by p4build@cyprus on 2010-11-02 at 15:59:20 PDT (gcc version 3.4.3)
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 123776k/131072k available (1611k kernel code, 7212k reserved, 444k data, 2576k init, 0k highmem)
    available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=13119488
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> .........................................................................................................................................................................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    No panic info av ailable
    <4>ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count 400
    AG7100: Max rx descriptor count 252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: d8:c7:c8:ce:af:a1
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    AP xml model 39, num_radios 2 (jiffies 1797)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    asap_gre_init: ADDED GRE protocol c009e5e8
    ath_hal: 0.9.17.1 (AR5416, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    wifi0: Base BSSID d8:c7:c8:6a:fa:18, 8 available BSSID(s)
    edev->dev_addr=d8:c7:c8:ce:af:a1
    wifi0: AP type AP-105, radio 0, max_bssids 8
    wifi0: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
    wifi1: Base BSSID d8:c7:c8:6a:fa:10, 8 available BSSID(s)
    wifi1: AP type AP-105, radio 1, max_bssids 8
    wifi1: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
    net.aruba_asap.br_init = 1
    Getting an IP address...
    ag7100_ring_alloc Allocated 4800 at 0x8055a000
    ag7100_ring_alloc Allocated 3024 at 0x86a8b000
    AG7100: cfg1 0xf cfg2 0x7014
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0 phy is up...RGMii 100Mbps full duplex
    AG7100: pll reg 0x18050010: 0x1099 AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0x7ffef
    AG7100: done cfg2 0x7115 ifctl 0x10000 miictrl 0x12
    Writing 4
    192.168.1.9 255.255.255.0 192.168.1.1
    Running ADP...Done. Master is 192.168.1.99
    <<<<< Welcome to the Access Point >>>>>
    ~ # Kernel watchdog refresh ended.
  • 4.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 04, 2014 04:21 PM
    What version of AOS is running on the 800 controller, and is CPSec enabled?
  • 5.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 03:26 AM
    Hi Its running a very old OS 3.4.3.2 which is before CPSEC was enabled. Isuspect i need to upgrade the OS
  • 6.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 06:35 AM
    Is 192.168.1.99 the Controller?  Type "show ap database" on the controller commandline to see the status of that AP.  Also, type "show log system 50" to see if you see anything about that AP...
  • 7.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 07:20 AM
    DB shows no AP's attached
    show log system 50 output
    uba 800) #show log system 50
    l 5 11:53:00 :315382: <CRIT> |fpapps| Reboot Cause: Power Failure.
    l 5 11:53:04 KERNEL: klogd started: BusyBox v0.60.4 (2010.11.02-23:44+0000)
    l 5 11:53:04 KERNEL: Aruba Networks Model A8xx
    l 5 11:53:04 KERNEL: ArubaOS Version 3.4.3.2 (build 25931 / label #25931)
    Jul 5 11:53:04 KERNEL: Built by p4build@cyprus on 2010-11-02 at 16:48:25 PDT (
    c version 3.4.1)
    l 5 11:53:04 KERNEL: Copyright (c) 2002-2010, Aruba Networks, Inc.
    Jul 5 11:53:04 KERNEL: i2c-dev.o: Registered 'System I2C Interface' as minor 0
    l 5 11:53:04 KERNEL: VFS: Disk change detected on device ide0(3,3)
    Jul 5 11:53:09 :399816: <ERRS> |fpapps| Initializing the Line Card for Caberne
    1
    Jul 5 11:53:09 :399816: <ERRS> |fpapps| Initializing the Cabernet STD Port Ca
    backs
    Jul 5 11:54:11 :313078: <ERRS> |fpapps| XSec Vlan Interface 4095 not found lin
    877
    877
    l 5 11:54:11 :313256: <WARN> |fpapps| Route resolve returned an Error
    l 5 11:54:25 :325022: <ERRS> |authmgr| Bogus VLAN ID:4095 received.
    --More-- (q) quit (u) pageup (/) search (n) repeat
    Jul 5 11:54:36 :304001: <ERRS> |stm| Unexpected stm (Station managment) runtim
    error at data_path_handler, 579, data_path_handler: recv - Network is down
    Jul 5 11:55:00 :303022: <WARN> |AP d8:c7:c8:ce:f1:1e@192.168.1.2 nanny| Reboot
    eason: No reboot message found.
    Jul 5 11:55:25 :303022: <WARN> |AP d8:c7:c8:ce:af:a1@192.168.1.9 nanny| Reboot
    Jul 5 12:00:24 :303022: <WARN> |AP d8:c7:c8:ce:f1:1e@192.168.1.2 nanny| Reboot
    Reason: AP rebooted Sat Jul 5 03:59:29 PDT 2014: SAPD: Unable to contact switch
    Called by sapd_hello_cb:4
    Jul 5 12:00:51 :303022: <WARN> |AP d8:c7:c8:ce:af:a1@192.168.1.9 nanny| Reboot
    Reason: AP rebooted Sat Jul 5 03:59:56 PDT 2014: SAPD: Unable to contact switch
    Hope this helps
  • 8.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 07:27 AM
    What is the output of "show ap-group default" and "show ap system-profile default"?
  • 9.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 07:56 AM
    Hi
    Output of commands as requested
    ruba 800) #show ap-group default
    group "default"
    rameter Value
    rtual AP N/A
    2.11a radio profile default
    2.11g radio profile default
    red AP profile default
    hernet interface 0 link profile default
    hernet interface 1 link profile default
    system profile M3
    2.11a Traffic Management profile N/A
    2.11g Traffic Management profile N/A
    gulatory Domain profile default
    Optimization profile default
    Event Thresholds profile default
    S profile ids-low-setting
    sh Radio profile default
    sh Cluster profile N/A
    uba 800) #show ap system-profile default
    system profile "default"
    rameter Value
    S IP N/A
    ckup LMS IP N/A
    S Preemption Disabled
    S Hold-down Period 600 sec
    ster controller IP address N/A
    D operating mode (AP-10x/12x only) normal
    Band g
    uble Encrypt Disabled
    tive VLAN ID 1
    P MTU N/A
    otstrap threshold 8
    quest Retry Interval 10 sec
    ximum Request Retries 10
    epalive Interval 60 sec
    mp Server N/A
    lnet Disabled
    MP sysContact N/A
    protect Server IP N/A
    protect Backup Server IP N/A
    roScout RTLS Server N/A
    LS Server configuration N/A
    artbeat DSCP 0
    ssion ACL N/A
    rporate DNS Domain N/A
    intenance Mode Disabled
  • 10.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 07:59 AM
    What is the output of "show ap sytem-profile M3"?
  • 11.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 08:04 AM
    M3 system-profile as requested
    ruba 800) #show ap system-profile M3
    system profile "M3"
    rameter Value
    S IP 10.2.112.96
    ckup LMS IP N/A
    ster controller IP address 10.2.112.96
    Band g
    tive VLAN ID 1
    P MTU N/A
    otstrap threshold 8
    mp Server N/A
    lnet Disabled
    MP sysContact N/A
    artbeat DSCP 0
    ssion ACL N/A
  • 12.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 08:06 AM
    That's your problem:
    LMS IP 10.2.112.96
     Do this:
    config t
    no lms-ip
     The AP system profile is redirecting your access points to 10.2.112.96.  Zeroing it out will allow your access points to come up.
  • 13.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 08:25 AM
    Thanks so much for your help.
    Is there a way of changing this from the web interface.? I have entered the command and got no errors but the show ap system-profile M3 command still shows the wrong ip address.
  • 14.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 08:29 AM
    What errors? Do you have two controllers? It would have to be changed on the master controller.
  • 15.  RE: AP-105 gets ip and sees controller address via ADP but not listed in Controller interface?
    Posted Jul 05, 2014 08:38 AM
    Josheph, Thanks so much for your help. It's pointed me in the right direction. I Deleted references to system profile M3 in profile management in the web interface. My access points then appeared in the web interface.
    Regards
    Vernon
