AP 105 high channel utilization
  • 1.  AP 105 high channel utilization
    Posted Oct 19, 2015 03:07 AM
    I have 10 APs (105 model) in virtual controller enviroment.On a virtual controller dashboard i found many time that some APs showed high channel utilization and at that time users of same APs cannot access intranet/internet resources.I have attached image herewith.
    Please help me out what is reason and solution for this????
  • 2.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 05:30 AM
    You can try:
    - Turning on "Broadcast Filter All" on all of your SSIDs
    - Using fewer SSIDs
    - Turning down the maximum transmit power in the ARM profile.
  • 3.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 05:48 AM
    Just enable the   Broadcast Filter All" on all of your SSIDs and attached the screen shot as well.Is there is need to optimize any other option??/
    Turning down the maximum transmit power in the ARM profile???? can you send me any fix vlaue.
  • 4.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 05:50 AM
    On that same screen, you can try changing your 2.4 ghz transmit rate to 11 and see if it helps.
  • 5.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 05:55 AM
    You mean i set the trasmit rates from 11---------54???
  • 6.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 05:57 AM
    Yes. That is separate from the ARM maximum transmit power that I mentioned before.
    How many access points do you have and what type?
  • 7.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 05:58 AM
    hi,
    I have 10 APs model 105.
  • 8.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 06:05 AM
    HI,
    After made these changes now 5 GHZ channel uitlization is high.attached the screenshot
  • 9.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 06:08 AM
    You can try also increasing the 5ghz minimum rate, as well, but you should have less issues on the 5ghz and should not have to do that usually.
  • 10.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 06:16 AM
    If those steps do not help, in addition, you can set the ARM minimum and maximum transmit power both to 12 and see if it helps:
    http://www.arubanetworks.com/techdocs/Instant_42_WebHelp/InstantWebHelp.htm?_ga=1.43038629.1615771646.1440445030#UG_files/ARM/Configuring_ARM-Features.htm%3FTocPath%3DAdaptive%2520Radio%2520Management%7C_____2
    You would then need to check to make sure you don't have any coverage holes after that.
  • 11.  RE: AP 105 high channel utilization
    Posted Oct 19, 2015 06:38 AM
    HI,
    Thanks for the help
    All changes have be made now i am monitoring and update you accordingly.
