AP-105 Instant AP sending Spanning-Tree BPDU's
  • 1.  AP-105 Instant AP sending Spanning-Tree BPDU's
    Posted May 21, 2014 07:40 PM
    HI, All  I recently setup a group of 10 Aruba105 Instant AP's.  After installation HP switch is complaining about receiving BPDU's and shutting the ports down.  I have the stp guard enable.   There is nothing else on the other end of cable except the AP.
    Has anyone experience this and what was the fix?
  • 2.  RE: AP-105 Instant AP sending Spanning-Tree BPDU's
    Posted May 21, 2014 09:05 PM
    Do you have it enabled in the wired settings ?
