AP 105 keeps associating with the master controller
  • 1.  AP 105 keeps associating with the master controller
    Posted Aug 18, 2015 04:14 PM
    I have 2 mobility 3200 controllers and all of the APs attach to the local except for one. I have renamed it, put a static IP on it, different group etc...
    Any ideas?
  • 2.  RE: AP 105 keeps associating with the master controller
    Posted Aug 18, 2015 04:16 PM
    Try erasing the configuring when it boots up.
  • 3.  RE: AP 105 keeps associating with the master controller
    Posted Aug 18, 2015 04:17 PM
    Was trying to avoid that, but i guess i have exhausted all methods.
  • 4.  RE: AP 105 keeps associating with the master controller
    Posted Aug 18, 2015 04:19 PM
    Also, do you have enough licenses on your local controller?
  • 5.  RE: AP 105 keeps associating with the master controller
    Posted Aug 18, 2015 04:35 PM
    Yes, that was the first thing i suspected.
  • 6.  RE: AP 105 keeps associating with the master controller
    Posted Aug 18, 2015 05:16 PM
    Just wanted to follow up after i discovered the issue. It had something to do with control plane security. I turned it off and like magic, they moved back to the local... Go figure.
