I had a power outage and 1 of our APs didnt come back. It just keeps rebooting. I tested all the cables and switches and they are fine. I replaced the AP with a spare to fill the coverage hole as a temporary fix.
I consoled into the AP and purged it. I didn't solve the problem. Do I need to RMA it or can it be fixed
Here is what the console output states:
uilt: 2011-01-07 at 13:42:04
Model: AP-10x
CPU: AR7161 revision: A2
Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
DRAM: 128 MB
POST1: passed
Copy: done
Flash: 16 MB
PCI: scanning bus 0 ...
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
Net: eth0
Radio: ar922x#0, ar922x#1
Hit <Enter> to stop autoboot: 0
Checking image @ 0xbf100000
Invalid image format version: 0xffffffff
Checking image @ 0xbf800000
eth0 up: 1 Gb/s full duplex
DHCP broadcast 1
DHCP IP address: REDACTED
DHCP subnet mask: 255.255.254.0
DHCP def gateway: REDACTED
DHCP DNS server: REDACTED
DHCP DNS domain:
Controller address: REDACTED
Using eth0 device
TFTP from server REDACTED; our IP address is REDACTED
; sending through gateway REDACTED
Filename 'mips32.ari'.
Load address: 0x2000000
Loading: #######checksum bad
checksum bad
##############T ###########################checksum bad
#######T ###
done
Bytes transferred = 4907804 (4ae31c hex)
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
Automatic boot of image at addr 0x02000000 ...
ELF file is 32 bit
Loading .text @ 0x80e00000 (4838904 bytes)
Loading .data @ 0x8129d600 (32 bytes)
Clearing .bss @ 0x8129d620 (16 bytes)
## Starting application at 0x80e00000 ...
Uncompressing.............................................
Aruba Networks
ArubaOS Version 6.4.3.6 (build 52927 / label #52927)
Built by p4build@lesbos on 2015-12-11 at 15:34:05 PST (gcc version 4.3.3)
CPU Rev: aa
71x CPU
Flash variant: default
Cache parity protection disabled
Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
Memory: 121600k/131072k available (1718k kernel code, 9360k reserved, 698k data, 4068k init, 0k highmem)
available.
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=19008512
LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ...................................................................................................................................................................................................................................................................................................
AR7100 GPIOC major 0
wdt: registered with refresh
Enabling Watchdog
Talisker RSSI LED initialization
Creating 1 MTD partitions on "ar7100-nor0":
0x00000000-0x01000000 : "flash"
i2c /dev entries driver
i2c-talisker: using default base 0x18040000
AD7416 driver probing for devices on AR7100 I2C
.<6>lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
AP-type has_ble_support: .
Domain Name: arubanetworks.com
No panic info available
Testing TPM... Failed -- Rebooting
killall: nanny: no process killed
killall: sapd: no process killed
SIOCSIFADDR: No such device
Sending SIGKILL to all processes.
Please stand by while rebooting the system.
Restarting system.
