ap 105 not connecting to controller
  • 1.  ap 105 not connecting to controller
    Posted May 30, 2014 02:57 PM
    When trying to install a new ap 105, I get the follow error during the boot. Others have not problems and it appears that it gets an ip address fine, why will this one not find the controller? I've factory reset with no luck. Any help is greatly appreciated.
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    eth0 up: 1 Gb/s full duplex
    DHCP broadcast 1
    DHCP IP address: 10.1.140.63
    DHCP subnet mask: 255.255.254.0
    DHCP def gateway: 10.1.140.1
    DHCP DNS server: 10.1.100.30
    DHCP DNS domain: whitehall.local
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    Retry count exceeded
    DNS request 1 for aruba-master.whitehall.local to 10.1.100.30
    T T T T
    Retry count exceeded; starting again
  • 2.  RE: ap 105 not connecting to controller
    Posted May 30, 2014 03:12 PM
    How is your AP finding master controller?
    Statically configured? Throguh DHCP option? By resolving aruab-master? through ADP multicast/braodcast?
  • 3.  RE: ap 105 not connecting to controller
    Posted May 30, 2014 03:37 PM
    APs get dhcp address from Windows dc then resolves aruba-master
  • 4.  RE: ap 105 not connecting to controller
    Posted May 30, 2014 04:40 PM
    It looks like the AP cannot contact your DNS server: 10.1.100.30 (hence the timeout message).  Are the other APs you have on the same network?  Can you plug a PC into that same port and atttempt to do an nslookup to that DNS server to make sure ?   Make sure your IP/mask information is correct.
  • 5.  RE: ap 105 not connecting to controller
    Posted Jun 02, 2014 09:04 AM
    That port is a 140 vlan port. Other Aruba aps 105s, 135s, and even 124s, all connect fine on the same vlan. for some reason these two won't. I've tried giving static ip and aruba master information and still can't get it to boot.
  • 6.  RE: ap 105 not connecting to controller
    Posted Jun 02, 2014 02:31 PM
    with the fixed settings, what output do you get on the console?
    i would double check that the switchport is correctly configured, try connecting another device and see if it gets IP and can do DNS correctly.
  • 7.  RE: ap 105 not connecting to controller
    Posted Jun 05, 2014 09:08 AM
    Well...for some reason the second time I added static ips it worked perfectly. I must have done something wrong. Now if I purgeenv and save then boot, I get a signed image but gets caught in the reboot loop below:
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
           01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  0
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (3779112 bytes)
    Loading .data @ 0x8119aa30 (32 bytes)
    Clearing .bss @ 0x8119aa50 (16 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing...................................
    Aruba Networks
    ArubaOS Version 6.1.3.6 (build 36470 / label #36470)
    Built by p4build@corsica.arubanetworks.com on 2012-12-11 at 12:16:36 PST (gcc version 4.3.3)
    CPU Rev: aa
    71x CPU
    Flash variant: default
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 122880k/131072k available (1850k kernel code, 8108k reserved, 693k data, 2960k init, 0k highmem)
     available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=12449792
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ..............................................................................................................................................................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    .<6>lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    Testing TPM... Passed
    ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count    400
    AG7100: Max rx descriptor count    252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: 6c:f3:7f:ca:74:d1
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    AP xml model 39, num_radios 2 (jiffies 4137)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    setting bond0 as bridge child
    setting gre0 as split child
    Starting watchdog process...
    Getting an IP address...
    ag7100_ring_alloc Allocated 4800 at 0x813be000
    ag7100_ring_alloc Allocated 3024 at 0x813b1000
    AG7100: cfg1 0xf cfg2 0x7014
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0: phy not up carrier 1
    Writing 4
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
    AG7100: pll reg 0x18050010: 0x110000  AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0xfffef
    AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    10.1.140.64 255.255.254.0 10.1.140.1
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    Restarting system.
       If I factory_reset I get the same boot as before with invalid image:
    apboot> boot
    DHCP broadcast 1
    DHCP IP address: 10.1.140.64
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    T T
  • 8.  RE: ap 105 not connecting to controller
    Posted Jun 05, 2014 12:00 PM
    One more update:
    If I add an reservation in the dhcp server for the 105 ap and then reboot it it connects just fine to the controller. The weird part is that if I reserved the 140.64 address it will won't connect with controller. If I reserved a new dhcp address it works just fine. Would the controller block ip address of aps? Like a blacklist?
  • 9.  RE: ap 105 not connecting to controller
    Posted Jun 05, 2014 02:21 PM
    Duplicate IP on the network, possibly a bad ARP cache somewhere between the AP and controller? You don't have any 'down' APs in the 'show ap database' using that 64 IP correct? The controller shouldn't block anything and the fact that your DNS wouldn't respond means it's likely outside of the controller anyway.
  • 10.  RE: ap 105 not connecting to controller
    Posted Jun 05, 2014 03:05 PM
    Thank you for the response. I will keep digging.
  • 11.  RE: ap 105 not connecting to controller
    Posted Jun 05, 2014 03:29 PM
    Oddly enough I did a show arp on the controller and found a 00:13:72... mac address using that 10.1.140.64 ip address. So...I cleared the arp table on the controller and  the 140.64 address went back to the Dell MAC address.
    So do you think I have a Dell computer somewhere plugged into a 140 (wireless) vlan port that is giving me issues?
  • 12.  RE: ap 105 not connecting to controller
    Posted Jun 05, 2014 03:31 PM
    Good question, you may have to trace the CAM tables through your network to find out what port it's on, if you don't already have some kind of NMS.
  • 13.  RE: ap 105 not connecting to controller
    Posted Jun 06, 2014 09:08 AM
    So now I have realized that if I block the .64 address in dhcp it then gets a .55 address. In dhcp it has the correct MAC address to match the ap. However, in the arp table on the controller, the .55 now has that same Dell Inc. MAC address. I'm so confused! Why would dhcp see the ap as it is but the controller see it as a Dell device.
    By the way, same person different account. :) Took a new job and was using former persons Aruba account until mine was verified.
  • 14.  RE: ap 105 not connecting to controller
    Posted Jun 06, 2014 09:52 AM
    Finally!!! It was not one Dell computer but FIVE! Somehow they got patched over in a TC to the POE switch and were on our wireless hardware vlan. Removed the deviced from the switch and the ap booted and jumped right on the controller!
    Thanks for all the help!
  • 15.  RE: ap 105 not connecting to controller
    Posted Jun 06, 2014 07:04 PM
    ice run down, those kinds of things are insidious.
  • 16.  RE: ap 105 not connecting to controller
    Posted Jun 06, 2014 07:58 PM
    Thanks! Feels good to get that figured out. Putting in 25 more aps next week so it will be nice to have the problem solved!
