We use 100s of Aruba AP-105. We have recently installed one AP to our building where CAT5e ethernet cable comes from the switch in different floor via the external wall. Its a external grade ethernet cable. The switch is Procurve 2620 PoE. The distance from the switch to the AP is about 40-50 metres.
AP Led status:
PWR - Green
ENET - Red
11 A/N - not lit
11 B/G/N - not lit
Laptop gets IP if I unplug the AP and plug the Laptop, however AP is not getting the IP at all. I have tried three different AP-105, all has exact same problem. If I plug these AP direct to the same switch on any ports then it gets IP.
I have also tried with the PoE Injector, but still it does not get the IP.
Is it the cable issue ?
Any help would be much appreciated, thank you.
