AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
  • 1.  AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 04:43 AM
    I have about 4 AP-105 to be deployed in my network. The clients receive IPs from a DHCP server service running on the PFsense firewall. This DHCP assigns to the clients the gateway IP of the CARP/virtual interface for the master and backup firewall. Unfortunately the clients  are having problems with the CARP. They cannot reach the CARP, no pings go through and the CARP interface IP cannot even be found in the ARP table of the clients.
    Does anyone have an idea or a solution?
    Thanks inadvance
  • 2.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 04:57 AM
    Hi Friend,
    Let me understand your network,
    1. What is the forwarding mode of the SSID ( VAP) where clients connected ?
    2. Is the the controller ( LMS) able to ping the Gateway ( Client GW) ?
    3. Is there any NATing enabled on the Client VLAN ?
    Please clarify these points,
    Please feel free for any further help on this.
  • 3.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 05:03 AM
    Thanks very much for the quick response:
    1. The VAP forwarding mode is in Access Mode
    2. Yes it is able to ping the virtual gateway.
    3. There is no NATing enabled on the client VLAN.
    thanks
  • 4.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 05:50 AM
    VAP Forwarding mode can not be Access mode, it can be either, Tunnel mode, Bridge Mode or Decrypt tunnel mode.
    It is very important to know the forwarding mode and the VLAN to fix this issue,
    to check the forwarding mode and VLAN use the following command,
  • 5.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 05:57 AM
    Thanks for your reply, this is an IAP-105 with a Virtual controller IP.  Find attached file.
  • 6.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 06:11 AM
    Hi Friend,
    Here we don't need to know the uplink status and the IP address of the AP because AP do not have any issue, Clients are having issue hence we should know the forwarding mode of the VAP and the VLAN mapped to the VAP.
    Please follow the above command and try to know the forwarding mode and the client VLAN.
    without the above information we can not fix the issue.
  • 7.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 06:33 AM
    how are you instant APs connected to the network? on a trunk port, can they reach all VLANs they need to reach? how are your clients assigned to a network / VLAN? please share you config.
    PS: dhanraj_puduch… this isn't a controller based setup, so you can't check the VAPs.
  • 8.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 06:52 AM
    I have just 1 VLAN (management vlan 1) and all ports are allowed. The ports are trunk ports and have access to the vlan. The clients were first being assigned IPs from the DHCP Server (PFSENSE). Now  the IAP assigns IPs to the clients.
  • 9.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 06:46 AM
    Hi, unfortunately the terminal doesnt accept the above command for checking the forwording mode. I get an error in command with "wlan".
  • 10.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 19, 2015 07:02 AM
    I completely misunderstood this as the controller based deployment, now realised that you are using IAP not the controller based APs :)
    please ignore that command it is not applicable for the IAP.
    please verify the uplink, it was showing as the access link, please ensure the following things are in place,
    1. what is the VLAN mapped to the SSID ?
    2. try to change the IAP uplink as the trunk as shown bellow.
    select "More-->Wired"
    Select "Default_Wired_Port_Profile ( Profile which is mapped to the 0/0) and select Edit :
    Apply the required changes ,
  • 11.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 21, 2015 05:05 AM
    version 5.0.3.0-1.1.0
    virtual-controller-country DE
    virtual-controller-key cff5adbf014426cfb9547bc010dfaad80ea4ee1ce5595390f1
    name Instant-C9:B1:B7
    terminal-access
    rf-band all
    allow-new-aps
    allowed-ap d8:c7:cd:de:gt:y6
    allowed-ap d8:c7cd:de:gt:y6
    mgmt-user admin e459252c207483972e0aa9b077beb5decc6bc17a857df186
    wlan ssid-profile wlan1
    index 0
    type employee
    essid wlan1
    wpa-passphrase b34cd25c5af6d9e461fce99f25671394b117494b299f1b5f
    opmode wpa2-psk-aes
    vlan guest
    rf-band all
    captive-portal disable
    wlan ssid-profile wlan2
    index 1
    type employee
    essid wlan2
    wpa-passphrase 270b4a7bdeac1347efa7a5f9a0292ca41ec431be0b87c469
    opmode wpa2-psk-aes
    rf-band all
    enet-vlan guest
    wlan access-rule wlan1
    index 0
    rule any any match any any any permit
    wlan access-rule wlan2
    index 1
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
  • 12.  RE: AP 105 problems with PFSENSE CARP (Virtual) Gateway IP
    Posted Jan 30, 2015 01:08 PM
    [edit] saw too late you did a whole lot of other things, do you still have this issue?
