AP-105 second radio stuck at am mode
  • 1.  AP-105 second radio stuck at am mode
    Posted Nov 24, 2015 11:40 PM
    Hi Guys,
    i'm implementing a new controller 7210 at my cust's site with few new AP 205 and 225.
    everything works fine but the old AP-105.
    all APs are using same config from the same AP Group but all my AP-105's second radio (11a) always stuck at am mode.
    below is the result of 2 APs (105 and 205) show ap active:
    APGRP_1  192.168.34.72   1            AP:HT:11/18/22.5     0            AM                   105      2aKr   1d:15h:36m:27s  N/A
    APGRP_1  192.168.35.78   10           AP:HT:11/18/22       5            AP:VHT:161/18/24     205      2aKr   2d:18h:50m:47s  N/A
    what config might causes this? i'm using 6.4.2.12
    Ricky
    #AP225
  • 2.  RE: AP-105 second radio stuck at am mode
    Posted Nov 25, 2015 12:05 AM
    You sure they are in the same group? Looks like two different groups since group name is right before the IPAddr.
  • 3.  RE: AP-105 second radio stuck at am mode
    Posted Nov 25, 2015 12:10 AM
    Ho Jerrod,
    yes they are on the same group. i edited the name because it contains cust's name, just a typo. they are one the same  group.
    Ricky
  • 4.  RE: AP-105 second radio stuck at am mode
    Posted Nov 25, 2015 12:23 AM
    Run a 'show ap allowed-channels ap-name <ap105 name>' and the same for a 205 and see what the output is. You may want to download a new DRT file if it shows unavailable channels on the 5Ghz for the AP-105. Are there any disallowed channels in the config? What country-code?
    Otherwise I am not 100% sure.
  • 5.  RE: AP-105 second radio stuck at am mode
    Posted Nov 25, 2015 12:51 AM
    Hi Jerrod,
    #show ap regulatory
    Regulatory Version :1.0_51155
    i upgraded the DRT:
    #show ap regulatory
    Regulatory Version :1.0_52480
    my supported channels:
     #show ap allowed-channels country-code id
    Allowed Channels for Country Code "ID" Country "Indonesia"
    PHY Type                 Allowed Channels
    802.11g (indoor)         1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (indoor)         149 153 157 161
    802.11g (outdoor)        1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (outdoor)        149 153 157 161
    802.11g 40MHz (indoor)   1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (indoor)   149-153 157-161
    802.11g 40MHz (outdoor)  1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (outdoor)  149-153 157-161
    802.11a 80MHz (indoor)   149-161
    802.11a 80MHz (outdoor)  149-161
    802.11a (DFS)            None
    but my 105 still doesnt work at 11a
    #show ap allowed-channels ap-name AP_GU-LT1_PDG
    Allowed Channels for AP "AP_GU-LT1_PDG" Country Code "ID" Country "Indonesia"
    802.11a (indoor)         None
    802.11a (outdoor)        None
    802.11g 40MHz (indoor)   None
    802.11a 40MHz (indoor)   None
    802.11g 40MHz (outdoor)  None
    802.11a 40MHz (outdoor)  None
    802.11a (DFS)            None
  • 6.  RE: AP-105 second radio stuck at am mode
    Posted Nov 25, 2015 02:15 AM
    the problem was in my regulatory domain.
    issue solved by changing the regulatory to another country.
    Ricky
