last person joined: 3 hours ago
AP 105 static IP
  • 1.  AP 105 static IP
    Posted Mar 27, 2018 10:55 AM
    Community,
    I would like to assign static IP addresses to all my Aruba 105 AP's but am having a hard time finding where to do this in the controller (3200xm). All the google searches come up for "instant AP's" but that is not what I have. How do i assign static IP's to my AP's? Do I have to do it via CLI at each individual AP?
    Thanks.
  • 2.  RE: AP 105 static IP
    Posted Mar 27, 2018 11:35 AM
    Configuration> Wireless> AP Installation.
    An Aruba Installation assumes that your access points will do dhcp, so there are very few places that support easy installation/maintenence of statically addressed access points.
  • 3.  RE: AP 105 static IP
    Posted Mar 27, 2018 11:48 AM
    Colin,
    Does this mean the only viable way to apply static IPs to an AP 105 is via CLI?
  • 4.  RE: AP 105 static IP
    Posted Mar 27, 2018 12:00 PM
    No.  While provisioning an AP in the GUI (to change the name or ap-group), you can set the static ip address parameters there.
  • 5.  RE: AP 105 static IP
    Posted Mar 27, 2018 02:52 PM
    Colin,
    I am having trouble finding where in the controller this is set at. i went to Configuration tab-->Wireless-->AP Configuration but am seeing nothing. I tried in both AP Groups and AP Specific tabs.
  • 6.  RE: AP 105 static IP
    Posted Mar 27, 2018 02:54 PM
  • 7.  RE: AP 105 static IP
    Posted Mar 27, 2018 03:03 PM
    Thanks Colin, I see it now! You have to check the AP and then click on "provision"
    Thanks!
  • 8.  RE: AP 105 static IP
    Posted Mar 27, 2018 03:37 PM
    You would have to do the same thing to change the name or group of an AP.
