AP 105 stuck with green flashing power light, have tried pugeenv
  • 1.  AP 105 stuck with green flashing power light, have tried pugeenv
    Posted May 21, 2013 05:07 AM
    Its on OS6 and the last command on the CLI is: cert_cap=0 that's it. It just sits there with a flashing green light, it is getting an IP address but not showing on our mobility switch. Any ideas before I RMA?
    Thanks.
  • 2.  RE: AP 105 stuck with green flashing power light, have tried pugeenv
    Posted May 21, 2013 05:11 AM
    :smileyhappy:
    Can u please screenshot your GUI of the controller under CONFIGURATION>WIRELESS>AP INSTALLISON
    *can u see there your AP? if yes what is the flag the written in the same line?
    Can u please screenshot or copy&paste your AP cli output? (using serial-cable)
    (at least 35 last lines,not only the last line please)
    *it will be helpful for us to assist u
    Me.:smileywink:
  • 3.  RE: AP 105 stuck with green flashing power light, have tried pugeenv
    Posted May 21, 2013 05:19 AM
    Also - Please try also to run "clear os" on the AP boot enviroment and not only purgenv>saveenv>boot
  • 4.  RE: AP 105 stuck with green flashing power light, have tried pugeenv
    Posted May 21, 2013 05:44 AM
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    .<6>lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    Testing TPM... Passed
    ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count    400
    AG7100: Max rx descriptor count    252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: 6c:f3:7f:c0:f2:89
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    AP xml model 39, num_radios 2 (jiffies 4140)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    setting bond0 as bridge child
    setting gre0 as split child
    Starting watchdog process...
    Getting an IP address...
    ag7100_ring_alloc Allocated 4800 at 0x8071c000
    ag7100_ring_alloc Allocated 3024 at 0x813c0000
    AG7100: cfg1 0xf cfg2 0x7014
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0: phy not up carrier 1
    Writing 4
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
    AG7100: pll reg 0x18050010: 0x110000  AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0xfffef
    AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    10.254.11.60 255.255.255.0 10.254.11.254
    Running ADP...Done. Master is 10.254.12.6
    ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_spectrum: Version 2.0.0
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    wifi0: Base BSSID 6c:f3:7f:8f:28:98, 8 available BSSID(s)
    bond0 address=6c:f3:7f:c0:f2:89
    br0 address=6c:f3:7f:c0:f2:89
    wifi0: AP type AP-105, radio 0, max_bssids 8
    wifi0: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
    wifi1: Base BSSID 6c:f3:7f:8f:28:90, 8 available BSSID(s)
    wifi1: AP type AP-105, radio 1, max_bssids 8
    wifi1: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
    Starting FIPS KAT ... Completed FIPS KAT
    shutting down watchdog process (nanny will restart it)...
            <<<<<       Welcome to the Access Point     >>>>>
    ~ # cert_cap=0
    The system is going down NOW !!
    Sending SIGTERM to all processes.
    Please stand by while rebooting the system.
    Restarting system.
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
           01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xbf100000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (3781400 bytes)
    Loading .data @ 0x8119b320 (32 bytes)
    Clearing .bss @ 0x8119b340 (16 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing...................................
    ú
    Aruba Networks
    ArubaOS Version 6.1.3.7 (build 37112 / label #37112)
    Built by p4build@cartman on 2013-02-08 at 17:45:35 PST (gcc version 4.3.3)
    CPU Rev: aa
    71x CPU
    Flash variant: default
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 122880k/131072k available (1850k kernel code, 8112k reserved, 693k data, 2964k init, 0k highmem)
     available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=12462080
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ...............................................................................................................................................................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    ag7100_ring_alloc Allocated 4800 at 0x813c6000
    ag7100_ring_alloc Allocated 3024 at 0x813b6000
    Writing 4
    Running ADP...Done. Master is 10.254.12.3
    AP rebooted Tue May 21 09:44:39 GMT 2013; SAPD: Reboot after successful image upgrade
    ~ # cert_cap=0
  • 5.  RE: AP 105 stuck with green flashing power light, have tried pugeenv
    Posted May 21, 2013 05:46 AM
    Now back in the office now, I checked the AP Pro list and its not there, I have done clean OS and also held the pin in and the same issue. Our controller is 10.254.12.3 and slave is 10.254.12.6. I might try and manually set the ip on the AP. Any other ideas?
  • 6.  RE: AP 105 stuck with green flashing power light, have tried pugeenv
    Posted May 21, 2013 05:48 AM
    Ok its popped up on the AP Pro list with flag IL.
  • 7.  RE: AP 105 stuck with green flashing power light, have tried pugeenv
    Posted May 21, 2013 05:54 AM
    U don't have enough License on your controller. That the "l" and because of it the AP is inactive "i"
    The ap is able to connect to your controller - just add more license to your controller - and it will work.
    Me
  • 8.  RE: AP 105 stuck with green flashing power light, have tried pugeenv
    Posted May 21, 2013 06:00 AM
    Seems a big install happened and the licenses were not activated! I am activating them now so that should solve it!
  • 9.  RE: AP 105 stuck with green flashing power light, have tried pugeenv
    Posted May 21, 2013 06:03 AM
    Yes sorted, red lights came on the second I added the license! Just need to re-pro it now and pop it back! Thanks for quick replies, knew it was something silly.
