AP 105's are unable to be provisioned by controller 620
  • 1.  AP 105's are unable to be provisioned by controller 620
    Posted Nov 19, 2013 11:47 AM
    hi guys,
    i have do a factory reset of my controller 620.
    after this, i tried to configure my AP, but they cannot link them successfully to my controller.
    i have two different situation.
    On one controller i receive this:
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU: AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM: 128 MB
    POST1: passed
    Copy: done
    Flash: 16 MB
    PCI: scanning bus 0 ...
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
    01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
    Net: eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0xbf100000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (5590776 bytes)
    Loading .data @ 0x81354f00 (32 bytes)
    Clearing .bss @ 0x81354f20 (16 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing.....................................................
    ú
    Aruba Networks
    ArubaOS Version 6.2.0.3 (build 37213 / label #37213)
    Built by p4build@corsica.arubanetworks.com on 2013-02-15 at 06:09:03 PST (gcc ve rsion 4.3.3)
    CPU Rev: aa
    71x CPU
    Flash variant: default
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 120960k/131072k available (1920k kernel code, 9984k reserved, 755k data, 4688k init, 0k highmem)
    available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=21110272
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ........................... ................................................................................ ................................................................................ ................................................................................ ........................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    .<6>lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    Testing TPM... Passed
    ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count 400
    AG7100: Max rx descriptor count 252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: d8:c7:c8:ce:d7:19
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    AP xml model 39, num_radios 2 (jiffies 5481)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    setting bond0 as bridge child
    setting gre0 as split child
    Starting watchdog process...
    Getting an IP address...
    ag7100_ring_alloc Allocated 4800 at 0x87b48000
    ag7100_ring_alloc Allocated 3024 at 0x86b0a000
    AG7100: cfg1 0xf cfg2 0x7014
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0: phy not up carrier 1
    Writing 4
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    AG7100: unit 0 phy is up...RGMii 100Mbps full duplex
    AG7100: pll reg 0x18050010: 0x1099 AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0x7ffef
    AG7100: done cfg2 0x7115 ifctl 0x10000 miictrl 0x12
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    DHCP timed out... valid v6 address present. continue
    fe80::dac7:c8ff:fece:d719/64 Scope:Link
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    Restarting system.
    On the other AP instead:
    Model: AP-10x
    DRAM: 128 MB
    POST1: passed
    Copy: done
    Flash: 16 MB
    Net: eth0
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    eth0 up: 100 Mb/s full duplex
    DHCP broadcast 1
    DHCP broadcast 2
    DHCP broadcast 3
    DHCP broadcast 4
    DHCP broadcast 5
    Retry count exceeded; starting again
    on this ap i have use the command " factory_reset"
    my controller have version 6.2.1.1
    have any idea?
    thanks in advance
  • 2.  RE: AP 105's are unable to be provisioned by controller 620
    Posted Nov 19, 2013 11:51 AM
    Can you try these three commands on one of them?
    purgeenv
    Saveenv
    Boot
  • 3.  RE: AP 105's are unable to be provisioned by controller 620
    Posted Nov 19, 2013 11:53 AM
    thank for your answer,
    well, yes on both AP's
  • 4.  RE: AP 105's are unable to be provisioned by controller 620
    Posted Nov 19, 2013 11:52 AM
    Both the Aps are not gettign IP address.
    DHCP timed out...
    on second
    DHCP broadcast 1
    DHCP broadcast 2
    DHCP broadcast 3
    DHCP broadcast 4
    DHCP broadcast 5
