AP-105s Will Not Boot
  • 1.  AP-105s Will Not Boot
    Posted Dec 23, 2013 03:37 AM
    I have received a new batch of 105 APs. I'm trying to connect them to my 6000 Controller with no joy.
    They keep rebooting in a loop. This is the output from console. Posted is the last piece of information before reboot.
    Testing TPM... TPM driver running in 3204 mode
    i2c_adapter i2c-1: sendbytes: error - bailout.
    Failed -- Rebooting
    killall: nanny: no process killed
    killall: sapd: no process killed
    SIOCSIFADDR: No such device
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    Restarting system.
    Any Ideas?
    Ian
  • 2.  RE: AP-105s Will Not Boot
    Posted Dec 23, 2013 04:20 AM
    Hmm I should probably do my research beforehand.
    Found another post with this information and it looks like they need to be returned...
  • 3.  RE: AP-105s Will Not Boot
    Posted Dec 23, 2013 08:31 AM
    Make sure that the APs are able to get a valid IP and that they can reach controller using ports 8211/47
    How are those APs reaching the controller: DNS, DHCP option 43, ADP ?
  • 4.  RE: AP-105s Will Not Boot
    Posted Dec 23, 2013 08:32 AM
    There is an issue with the AP
    You need to open a support case with the TAC
    Also before that check out if this isnt your issue... read the document im attaching you...
    Cheers
    Carlos
    Attachment(s)
  • 5.  RE: AP-105s Will Not Boot
    Posted Dec 23, 2013 09:18 AM
    Yep thats most likely the issue, the APs are newer than the listed serial numbers and my controller is 6.1.2.5.
    I will upgrade test
    Many thanks for the help
