AP 120
  • 1.  AP 120
    Posted Jan 31, 2012 09:46 PM
    The data sheet  on the AP 120 says "Software-configurable single radio capable of supporting 2.4 GHz or
    5 GHz" so how do you do it?
  • 2.  RE: AP 120
    Posted Jan 31, 2012 10:45 PM
    It will have to be done on the controller.  I think it's in the AP system profile or RF profile.
  • 3.  RE: AP 120
    Posted Jan 31, 2012 11:28 PM
    Hi Salvi
    I've check the AP system profile and "g" RF band has been selected.  But when I look at the AP's only half of them are running on 2.4 gig
  • 4.  RE: AP 120
    Posted Feb 01, 2012 12:01 AM
    Paulk,
    "show ap active" will tell you how many APs are indeed on the 2.4ghz as opposed to the 5ghz.  It will also tell you exactly what model you have.
  • 5.  RE: AP 120
    Posted Feb 01, 2012 12:13 AM
    Hi cjoseph,
    Atfter running the command "show ap active" I have 13 120's, 4 are on 11g, 7 are 11a and 2 are Air moinitors
  • 6.  RE: AP 120
    Posted Feb 01, 2012 12:15 AM
    @paulk wrote:
    Hi cjoseph,
    In the AP system profile, the RF band parameter determines if what band a single-band AP like the AP120 ends up on.
    The radio profile determines what is an Air monitor.
    There could also be an AP-specific configuration that only applies to each AP.  Under configuration> wireless> AP installation, see if there is any AP-specific configs.
  • 7.  RE: AP 120
    Posted Feb 02, 2012 05:45 PM
    There are no AP-specific configs
  • 8.  RE: AP 120
    Posted Feb 03, 2012 01:08 AM
    So you probably have different ap-groups, then and those control what band the access point broadcasts on, or even if it is an Air Monitor or not.
  • 9.  RE: AP 120
    Posted Feb 05, 2012 06:29 PM
    True, we have serval groups bit all the 120's are in the same group and in the same location
  • 10.  RE: AP 120
    Posted Feb 05, 2012 06:31 PM
    please open a support case if you have not done so already.
    EDIT:  Before you do that, use the "show ap config" command to see where your AP is getting its config.  The "source" column will tell you.
    (host) # show ap config ap-name AP135
    Configuration for AP name "AP135" AP group "default"
    Parameter                                                       802.11g                         802.11a                Source
    LMS IP                                                          N/A                             N/A                    ap system-profile "default"
    LMS IPv6                                                        N/A                             N/A                    ap system-profile "default"
    Backup LMS IP                                                   N/A                             N/A                    ap system-profile "default"
    Backup LMS IPv6                                                 N/A                             N/A                    ap system-profile "default"
    LMS Preemption                                                  Disabled                        Disabled               ap system-profile "default"
    LMS Hold-down Period                                            600 sec                         600 sec                ap system-profile "default"
    Number of IPSEC retries                                         360                             360                    ap system-profile "default"
    LED operating mode (11n APs only)                               normal                          normal                 ap system-profile "default"
    RF Band                                                         g                               g                      ap system-profile "default"
    Double Encrypt                                                  Disabled                        Disabled               ap system-profile "default"
    Root AP                                                         Disabled                        Disabled               ap system-profile "default"
    Native VLAN ID                                                  1                               1                      ap system-profile "default"
  • 11.  RE: AP 120
    Posted Feb 05, 2012 11:09 PM
    I've opened a case but as you can see the rf band is g with a source of "default" but the a band is active
    Configuration for AP name "somew.1.1.11" AP group "SomersbyScanners"
    (P7FUJI01) # show ap active ap-name somew.1.1.11
    Active AP Table
    Name          Group             IP Address    11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type  Flags  Uptime           Outer IP
    SOMEW.1.1.11  SomersbyScanners  10.96.120.32  0                                 0            AP:HT:60+/21/22      120      EB     68d:16h:53m:42s  N/A
