AP-125 does not maintain up status
  • 1.  AP-125 does not maintain up status
    Posted Jun 12, 2013 04:20 PM
    I have configured a 3200XM controller that I want my AP-125 to talk to. Instead of going the DHCP route, I decided to just assign the AP a static IP and it seems to connect to the controller. The AP shows up in the AP list but it only shows a status of "up" for about 20-30 seconds after it is rebooted. After that, it shows a "down" status and does not recover unless I log in to the AP CLI and give it a reboot.
    On the CLI I see:
    eth1:   1Gbs Full duplex, port  0, queue  0
    shutting down watchdog process (nanny will restart it)...
    ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    bonding: bond0: link status definitely up for interface eth1.
    bonding: bond0: making interface eth1 the new active one.
            <<<<<       Welcome to the Access Point     >>>>>
    ~ # cert_cap=1
    vap aruba000 vlan is 0. discovering tunnel vlan
    vap aruba100 vlan is 0. discovering tunnel vlan
    bonding: bond0: releasing active interface eth1
    bonding: bond0: now running without any active interface !
    ADDRCONF(NETDEV_UP): eth1: link is not ready
    eth1: Link down
    I am only connecting the ETH1 interface on the AP to the second port on the controller. I don't understand why it goes from:
    eth1: link becomes ready <<I assume this is when it is shown as the "up" status on the controller
    to a few lines later:
    Why is it releasing the interface?
    #3200
  • 2.  RE: AP-125 does not maintain up status
    Posted Jun 12, 2013 04:34 PM
    You should move your connection to e0
  • 3.  RE: AP-125 does not maintain up status
    Posted Jun 12, 2013 05:05 PM
    Oh ok, will do in the morning and report back. Why is that may I ask?
    And also if I run "show log system 50" on the controller CLI I see errors for:
    Reboot reason: AP rebooted (date); Unable to set up IPSec tunnel, Error: RC_ERROR_IKEP1
  • 4.  RE: AP-125 does not maintain up status
    Posted Jun 12, 2013 06:51 PM
    Are you setting this AP as RAP by any chance ? or do you have CPSec enabled ?
    Because campus APs should build up a GRE Tunnel unless configured as a RAP
    Also can you check your ethernet port 1 configuration profile for that particular AP-Group that the AP is part of :
  • 5.  RE: AP-125 does not maintain up status
    Posted Jun 13, 2013 10:34 AM
    I got the access point to show up and stay up on the controller once moving to eth0 so thank you very much for your help. I just have a couple questions:
    Is there a way to disable the wireless beacons until I am ready to use them? Right now I am just disabling the whole port that the AP is connected to the controller on and will enable when I am ready to bring the AP back on line.
    Since I am not ready to use the AP just yet, and I do not provision the AP, there is on way to log into it until I set up AP Installation and specify a username and pasword, correct? I can pick up the WLAN SSID from my phone but I don't believe I set up any credentials yet.
  • 6.  RE: AP-125 does not maintain up status
    Posted Jun 13, 2013 10:57 AM
    You can turn off the radios under the radio 11a/g11 profiles :
  • 7.  RE: AP-125 does not maintain up status
    Posted Jun 12, 2013 05:22 PM
    Aruba recommends using e0
