AP-125 - How to access apboot> via hyperteminal
  • 1.  AP-125 - How to access apboot> via hyperteminal
    Posted Dec 05, 2012 02:42 AM
    hey
    i need to clear os on an ap-125
    however need an idea on where to get started?
    can i access the apboot prompt by booting the ap over the lan to give it power?
    ive started a connection in hyperterminal and when i power up the ap using the lan i just get a whole heap of jiberish text and dont end up with any apboot> prompt.
    can someone please help?
  • 2.  RE: AP-125 - How to access apboot> via hyperteminal
    Posted Dec 05, 2012 03:36 AM
    Plese try follows.
    AP Reset Procedure
    10. Connect Console Cable to AP
    11. Pull out power cable of AP and insert again
    12. When screen says "Hit Enter" - Hit Enter
    13. Then, type: "purge" followed by Enter key
    14. Type: "save" followed by Enter key
    15. Type: "boot" followed by Enter key
  • 3.  RE: AP-125 - How to access apboot> via hyperteminal
    Posted Dec 05, 2012 06:30 AM
    @paradoxzero wrote:
    hey
    Make sure you have "no Flow control" configured on your Terminal Configuration.
