AP 134's wont find controller
  • 1.  AP 134's wont find controller
    Posted Oct 01, 2013 02:48 PM
    We just recieved 4 AP 134's. We are trying to get them working with our 3200 controller. I have confirmed they are not the Arube Instant  versions. Our 124's, 105's, and older 70's find the controller and show up as unprovissioned. Have I missed something with this model?
    #3200
  • 2.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 03:15 PM
    Make sure you have enough licenses :
    show ap license-usage
    show licenses
    Also console into the AP to see what's going on.
    Make sure is able to get an IP address
  • 3.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 03:18 PM
    Are these 134s brand new or used?  Have you purged the config if they are used (requires a console cable)?  What code version on the controller.
  • 4.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 03:22 PM
    I have plenty of licenses and it is pulling a good AP. They are brand new radios with no configs. Our Controller is running 5.0.4.7.
  • 5.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 03:27 PM
    I am not a long time Aruban but that cdoe is quite dated. I would check to see if the 134/135 is supported on that version. My hunch is that it's not.
  • 6.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 03:28 PM
    Seth is right, in order for you to support 135 you need 6.x
  • 7.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 03:31 PM
    There are only 12 currently. I have licensing for up to 28. I was under the impression that our 3200's could handle up to 250 radios.
  • 8.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 03:32 PM
    No...the 3200 can only support 32 APs.  Plus on that platform, you need the extra memory upgrade to support our later codes.  Sorry you were told wrong information.
  • 9.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 03:51 PM
    So then these 134's are useless to me?
  • 10.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 03:54 PM
    No...you can upgrade to the latest 6.1.x code version which is supported by BOTH the 134 and 3200 controller.  6.2 and 6.3 requires the memory upgrade.
  • 11.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 04:34 PM
    Updating to 6.1 allows me to provision the AP's. Now for some reason I cant seem to get greater than 54G speeds.
  • 12.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 04:42 PM
    Wow!  That was quick.  OK.  Under the ssid profile, you need to enable HT in the HT Profile.
  • 13.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 05:34 PM
    That worked. Thank you for all your help.
  • 14.  RE: AP 134's wont find controller
    Posted Oct 01, 2013 05:55 PM
    Since you're on 6.1...enjoy the Dashboard added in that version!  You will like it.
